#3331 | |
If you want to see pics of my table when I was building it ill be more than happy to post up some. |
#3332 |
![]() Join Date: Jul 2003
![]() ![]() Feedback Score: 7 reviews
First off I didn't do the welding, local drag shop that builds chromoly tube frame cars did it for me, said he would rather TIG it than MIG it and the price he gave me I wasn't going to turn him down. I did all the metal work and came up with the design. Its a stock bumper hidden winch mount for my '03 Xterra (supercharged). The pre-bent winch plate and clevis mounts are from ballistic fab. It will get rid of the stock pin dick metal bumper behind the grey/silver part of the lower "bumper", and that plastic piece hasn't been on my truck since it got ripped off last february.
Next project will probably be a rear bumper with spare tire carrier, the guys that welded it up said they have no problems with side projects and would bend me any tube I wanted for the projects as well. |
#3334 | |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
NEED Bolt kits for your car? |
#3337 | |
#3338 |
Trader Rating: (82)
I welded my battery tray and power steering... This is all done with a Lincoln 3200 hd I bought from home depot... I preheated the 1/8 metal to get a better weld any critiquing ???
#3339 |
#3340 |
Just curious y you chose that location for your battery.
otherwise fabwork looks good
cONtRol FReAkS |
#3341 |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Do you guys have any suggestions for MIG welding 4130 Chromoly steel that's 1" x .058"? I'm using a Millermatic 252 on, iirc 82% Argon 18% CO2. Or do you think I should just TIG it? The reason I want to go MIG is because I know it'll save a bunch of time for the project and time is kinda against us.
#3344 |
Trader Rating: (82)
Because I want my methanol pump installed next to the cold side of the intercooler pipes and it cost more if I extend the lines for the pump... So it's much cheaper to run a longer wire for the battery
#3345 |
![]() Join Date: Feb 2010
![]() ![]() Feedback Score: 20 reviews
So it's been decided, I will be buying a welder very shortly here and had some questions for you master fabbers.
I took a couple of years of welding in high school, mostly stick welding on mild steel, but had my fare share of stainless, and mig welding experience also. The only real "fab work" I've done is popping some tacks on in interior wall frame at a paint shop in Gary for a favor. Back to the main point. I'm looking at getting a mig welder and re-igniting my love affair with welding/fab work. Welder will be used for stitch welding, possible cage install, chassis gussets, etc. Question is what Mig to go with? Looking for something quality but not overly expensive, say $500 dollar range or so. So any advice you guys could give would great. I'm sure there is some talk about welders in the thread somehwere, but working full-time and school full-time make it difficult to search through a hundred or so pages. Plus curious as to what personal opinions are from personal experience with some welders. Thanks guys!
@MMyriad |
#3346 | |
![]() Join Date: Jan 2005
Look into maybe an HTP machine. I have heard really good things about them. Other than that stay with the bigger names...Miller, Lincoln, Hobart, Esab...ect. Do Not get a welder from Harbor freight. It would just be an exercise in frustration. Hope this helped a little. |
#3347 |
Trader Rating: (82)
So after 25 dollars and a couple of hours of fabricating I finished my strut bar Ideally I wanted the front strut bar without any bends but it was not possible unless I dropped the motor or lifted the hood with washers, did not want to do any of that. I know it's best to have a straight bar across the towers, but in my case it was not possible... The bars going to the firewall are straight attached to a 1/8 plate which bolts on to another 1/8 plate behind the firewall.. The plates for the shock are also 1/8 thick. I made them from scratch, I rounded them off to give a nicer appearance... I just need to weld a master cylinder brace. But any inputs what you guys might think about the bar?
#3348 | |
If the car's going to be competitively driven (I see the bash bar), why would you put the battery where it's guaranteed to get knocked around?
#3349 | |
#3350 | |
Once you get the BMC stopper put on have someone stomp on the brakes for you so you can see if it moves around on you. |
#3351 | ||
Trader Rating: (82)
Yeah, I know lol.... I just don't want to go to a hassle of having a cut off switch... I just want everything.... I need to learn how to drift first before I can compete with other cars... And it's a drycell but I know where u coming from.... Quote:
The longest time was cutting out the plates! Yes, I felt a difference in how it feels with and without it... Know I know why bars cost some decent money for all the time consumption
#3352 | |||||
![]() Join Date: Oct 2006
Those Ballistic tabs look to be around 1'' thick? And your plates around 1/4''? There should have be a square plate welded under the tab. You see this a lot in Jeep fab. It helps distribute the load on the thinner material. Significantly reduces the chances of that tab shearing right off. Quote:
You put yourself and other at risk of injury. Or worse. Why does everyone with a welder suddenly think they're capable and ready to weld things as critical as roll cages right off the bat? |
#3354 | |
The metal needs to be allowed some flex. Or else, like I said, it becomes brittle and it will crack. Obviously resulting in a failure. Now that's not to say er80 won't work. I'm just suggesting er70 as a better alternative due to the fact it allows it to be more ductile. MIG or TIG. Er80 and er70 are the exact same for both processes. The only difference is the process itself. Er80 for mig is still the same er80 for tig. |
#3355 |
As far as experience, I've done other work, just decided the to highlight the one job not for myself. By cage install, meaning installing a weld in cage, shouldn't be too hard to mig that in. I have 2 years plus of experience, just been a while since I've welded, hence saying re-ignite. Anyways, thanks for the input from those of you who gave it. I'll be ont he search for a little while.
On another topic, will you be making any more of those strut tower bars? Maybe a solid bend for the front bar? I'd be interested in that shit then.
@MMyriad |
#3356 |
![]() Join Date: Mar 2009
She's all done, the alignment is all messed up but she drives pretty good, just waiting on some adj arms. This spring were doing a fuel cell setup when we do the sr20, but were just putting that off till later.
#3358 | |
Finished mount, despite all the mud, the winch didn't see any action this weekend. That was early in the day while the truck was still clean. |
#3359 |
Looking good Chamb-O. Your on the right track. What is your set up? if you dont mind me asking.
Here are my ss welds from last week. My biggest problem is consistency. Just takes practice though. |
