Old 10-29-2012, 10:14 PM   #1
Stunt'nSlide
Trader Rating: (-1)
Stunt'nSlide is an unknown quantity at this point
Feedback Score: -1 reviews
Timing marks jumping around ka24e
I have a 89 ka24e and when I try timing the car the marks on the pully keep jumping around when I have the light on it. So I can't get the correct timing. What could cause this?
Stunt'nSlide is offline   Reply With Quote
Old 10-29-2012, 10:54 PM   #2
zerodameaon
zerodameaon's Avatar
Did you unplug the TPS? If you have not that is why your seeing the timing jump around. You also need to make sure the car is up to temp, drive it around for a little bit before you do so.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
Old 10-29-2012, 11:28 PM   #3
Stunt'nSlide
Trader Rating: (-1)
When I unplug the tps do I unplug both connectors? The 2 wire and 3 wire one?
Old 10-30-2012, 10:08 AM   #4
Stunt'nSlide
Trader Rating: (-1)
bump. anyone?
Old 10-30-2012, 11:24 AM   #5
zerodameaon
Try both, its been some time since I did a single cam but I am pretty sure we undid both. Regardless its not going to hurt anything if you do.
Old 10-30-2012, 01:36 PM   #6
Stunt'nSlide
Trader Rating: (-1)
Ok thanks. If its not that what else could it be? And also would a bas coolant temp sensor cause high idle and running rich?
Old 11-01-2012, 01:55 AM   #7
zerodameaon
If your temp sensor is old replace it. IDK if I keep getting crappy ones or what but i have noticed its about once a year it needs replacing.
Old 11-01-2012, 09:58 AM   #8
Stunt'nSlide
Trader Rating: (-1)
I replaced mine and still the same thing
