Peak performance, blitz dd, hotpipe, autometer pod
City: Medford
State/Province: OR Price: Varies Item Description: so i have a few things up for sale... first is a set of s13/s14 Peak performance "street" outter tie rods (tie rod ends). they are the exact same ones seen here: Peak Performance Street Outer Tie Rods S13/S14 they are beefier then the tien ones that most people get and around the same price. they work great, im using a set on my car but i accidently bought two sets so im selling this one. SOLD! pics: Blitz blow off valve only with no hotpipe, the fitting with the nipple for the vacuum line is missing but you can pick those up at a store that sells metric fittings for cheap. $100 shipped last is an s13 autometer 2 gauge pillar pod brand new. comes with everything new in the box except the top hole is cut out bigger for a 60mm gauge (does not come with the greddy gauge!) the lower hole is for a normal size gauge. $25 shipped thanks! Last edited by change; 12-07-2008 at 07:21 PM.. |
![]() Join Date: Jun 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
just to let you know the vacuum fitting is not as easily found as you think. its bspt and not npt (meaning u most likely will not find at a store). I had to get a replacement one and it took over 2 months and cost 30 bucks. I had canceled the ordered but it was still sent to me but i had already tapped it for npt.
460
2 bump limit. You can start new thread in 3 days.
