Old 12-22-2008, 08:03 PM   #1
speed_demon
speed_demon is an unknown quantity at this point
ebay clutches?
im needing a clutch for my car but im not wanting to spend to much because in about 3 months ill be doing the sr swap but i do need a clutch with more clamping power than stock because im spraying my car with a 125shot
i was looking at ebay and wanting to know if anybody has used any of them and how the clutches did
please give me your feed back thankyou
125 shot,4-2-1 header,3" headerback,13.783 at 101.75 on the bottle
speed_demon is offline   Reply With Quote
Old 12-22-2008, 08:11 PM   #2
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
i have heard of some people having luck with the XTD ebay clutches and the f1spec's. Search on here im sure there is a thread about it.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 12-22-2008, 10:15 PM   #3
projectRDM
projectRDM's Avatar
There is no such thing as an Ebay clutch. There are clutches of various manufacturers sold on Ebay, that's it. Since you failed to mention a name, give a link, or provide any useful information, no one can help you.
FORMERLY R240NA
Old 12-22-2008, 10:29 PM   #4
Teddy
Teddy's Avatar
Trader Rating: (44)
Teddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfection
Feedback Score: 44 reviews
I'm using a XTD stage 3 6 puck for my SR.
Could be the throw-out-bearing, but my car gets stuck in gear and I can't put it in gear. This clutch / bearing are only a few months old.
www.realize-jp.net
Teddy is offline   Reply With Quote
Old 12-22-2008, 10:31 PM   #5
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
You are probably better off getting the clutch "rebuilt" by a local shop than trying to use a cheap ebay clutch. Its probably going to be cheaper too.
VQMaxFan is offline   Reply With Quote
Old 12-23-2008, 02:00 AM   #6
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
F1 :P
http://www.youtube.com/watch?v=9WDFWiRPHBA
flip3d is offline   Reply With Quote
Old 12-23-2008, 11:42 AM   #7
killab18
killab18 has made poor choiceskillab18 has made poor choiceskillab18 has made poor choiceskillab18 has made poor choiceskillab18 has made poor choiceskillab18 has made poor choices
^^i think that said it all. stock clutches are about $150 at like autozone i believe. also have you looked into SBC clutches. I have one of theirs and couldnt be happier. in the car for close to a year and not a single problem. Running 12psi at about 300whp and not a single slip yet. i also have one of their 6 puck setups to hold 720ft tq but havent used that one yet.
killab18 is offline   Reply With Quote
Old 12-27-2008, 07:32 AM   #8
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
There is a company on ebay that is selling the oem nissan clutch kit that comes with the throwout bearing, pilot bushing, pressure plate, and clutch disc. IIRC the price was reasonable too.
-Retired
98s14inaz is offline   Reply With Quote
Old 12-28-2008, 12:29 AM   #9
schmauster
schmauster is an unknown quantity at this point
A stock nissan hardbody flywheel and a cheap 300zx stock replacment clutch should hold on.. lots of people having good luck on this setup.. gives more clutch surface area since the hardbody flywheels are 240mm.... Its called a white bunny special
schmauster is offline   Reply With Quote
Old 12-28-2008, 12:37 AM   #10
jrbump
jrbump's Avatar
jrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond repute
If you are swapping out in 3 months then just buy an OEM replacement cheapo and lay the fuck off the bottle. LOL.
jrbump is offline   Reply With Quote
Old 12-28-2008, 12:45 AM   #11
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
I have the same problem with mine, clutch also sometimes gets stuck half engaged but that's only if I dump it from high revs right after I turn the car on. (I like to abuse my car.)
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
chibo is offline   Reply With Quote
