Old 09-16-2016, 11:44 AM   #1
Enjuku Racing
Enjuku Racing - ISR S13 SR20DET Engine Gasket Kit
ISR Performance OE Replacement Engine Gasket Kit - Nissan SR20DET S13
ISR Performance is proud to offer OE Replacement Gaskets. With great success of our other OE replacement parts ISR Performance has become determined to provide more and more high quality OE Replacement, hard to find JDM Parts.
Kit Includes:
ISR Performance OE Replacement RWD SR20DET Rear Main Seal
ISR Performance OE Replacement RWD SR20DET Front Main Seal
ISR Performance OE Replacement RWD SR20DET Intake Valve Seals
ISR Performance OE Replacement RWD SR20DET Exhaust Valve Seals
ISR Performance OE Replacement RWD SR20DET Timing Chain Tensioner Gasket
ISR Performance OE Replacement RWD SR20DET S13 Valve Cover Gasket Set
ISR Performance OE Replacement RWD SR20DET S13 Intake Collector Gasket
ISR Performance OE Replacement RWD SR20DET S13 Intake Manifold Gasket
ISR Performance OE Replacement RWD SR20DET S13/14/15 Exhaust Manifold Gasket
ISR Performance OE Replacement RWD SR20DET Turbine Inlet Gasket (4 bolt)
ISR Performance OE Replacement RWD SR20DET T25 Turbine Outlet Gasket (5 bolt)
ISR Performance OE Replacement RWD SR20DET T25/28 Compressor Outlet Gasket (3 bolt)
ISR Performance OE Replacement RWD SR20DET Oil Pick Up Tube Gasket
ISR Performance OE Replacement RWD SR20DET Oil Pump Front Cover O-Ring
ISR Performance OE Replacement RWD SR20DET T25 Turbo Oil Drain Gasket
ISR Performance OE Replacement RWD SR20DET Oil Filler Cap O-Ring
ISR Performance OE Replacement RWD SR20DET S13 Throttle Body Gasket
ISR Performance OE Replacement RWD SR20DET Side Feed Injector O-Ring Pack inc FPR
ISR Performance OE Replacement RWD SR20DET Cam Angle Sensor O-Ring
ISR Performance OE Replacement RWD SR20DET S13 Idle Air Control Valve (IACV) Gasket
In Stock and Ready to Ship!
$89.99
http://www.enjukuracing.com
questions@enjukuracing.com
