Old 07-15-2012, 08:07 PM   #1
nsfmike240
nsfmike240 is an unknown quantity at this point
sr20det upper oil pan leaking
My upper oil pan is leaking, am i able to loosen motor mounts and lift it up high enough to pull out oil pan so i able to clean the top side of it? What do most people use ultra grey or ultra black, Thanks
nsfmike240 is offline   Reply With Quote
Old 07-15-2012, 11:37 PM   #2
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
wangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfection
Feedback Score: 36 reviews
Send a message via AIM to wangan_cruiser
U need to drop the sway bar and crossmember with a few inches until u get good clearance on it. I used the copper type i dunno but it never leaks on me.
wangan_cruiser is offline   Reply With Quote
Old 07-19-2012, 09:00 PM   #3
wadestone13
wadestone13 is an unknown quantity at this point
maybe your oil plug is not secured properly, worn or damaged. or maybe..... the oil filter is not attached correctly. either way you should bring your car to the mechanic. we all know how risky this is. oil is like our car's blood and without it, of course our car might die. lol. but anyway if still things aren't working out maybe you should replace your oil pan already. try searching on google for some parts. or use what i am always using for situations like this (http://www.carpartswholesale.com/cpw/oil_pan.html). cheers and good luck.
_____________________
wade
”It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
wadestone13 is offline   Reply With Quote
