so yeah when i started to get into drftng i saw all my buddies with s- chasis cars initiating using the E-brake but unfortunately my 350z doesnt use the actual brake they're small shoes ..so i researched and found a couple options . but money was always an issue but i heard of some company call CNC they're product are reasonably priced so after so long nights and like 2qts of brake fluid on my carpet this is what resulted ......after the install the hydro doesn't affect pedal feel , I was still able to keep my ABS unit , but i do have to deactivate it in order to use the Hydro properly with the ABS going crazy......
Was this a staging brake used as an hydrobrake now?
http://www.facebook.com/BaddlineCust...lision?fref=ts |
![]() Join Date: Dec 2006
Not bad, looks like your legs gonna rub on it?
I just installed one in my buddies
^^^ nice job, super clean install on the MAX SLC Hydrobrake !!
O.P. dont those metal straps flex like a mother fer? Even when we weld our brake to the tranny tunnel we have to reinforce it quite a bit to keep the sheet metal from flexing.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
i have problem locking up the rear also with my CNC staging brake.
i can lock up only when weight is shifted to one side. never locks up going straight no matter how slow i go. is it because of my stock z33 VLSD? |
#17 |
Spirit Of Ecstasy
![]() Join Date: Dec 2007
Not sure what you mean here is What mine looks like uploadfromtaptalk1307178330012.jpg
^^i like your shift knob
i bled the brakes more today. i could lock up going straight around 50 mph but after like 3 times, it didn't lock up. i parked the car and my rear pads were freaking smoking the crap out lol smells bad for sure. is this normal? Maybe it didn't lock because my pads faded after 3 lock ups... i have stoptech street performance. |
#22 |
Are all CNC staging brakes like this? free play in handle?
http://s785.photobucket.com/albums/y...t=IMG_1240.mp4 |
| 350z, e-brake, hydro |
