Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34. |
04-18-2011, 01:43 PM | #1 |
Evo brembos on 350z?
I have searched the forums for an answer and cannot find it. I have a 03 350z base model and I also have a extra set of evo calipers and rotors for all four corners. Before I tear into this on my next days off I was wondering if any of you guys have done this? Do I need to make an adapter bracket like on the 240sx or do they bolt up? Any information would be helpful....
08-19-2011, 10:15 PM | #3 |
I'd start off by checking the part number for those calipers against brembos between the Z and the EVO. Might just be a bolt on affair.
Sent from my HTC EVO 3D using Tapatalk
Tommy:1993 Lexus SC300 5 Spd |
08-19-2011, 10:19 PM | #4 | ||
Trader Rating: (63)
Feedback Score: 63 reviews
You will need a bracket to mount Front Calipers and some more pain for the rear. Touge Factory sells brackets for Evo brembo conversion. or I have 1 for sale as well. and of course you will need Evo rotors too. |
08-19-2011, 10:19 PM | #5 | |
Im not sure but I will use an IF/Then Analysis from good ole jhs days.
If 350z brembos fit stock 240sx (after enlarging the hole) AND Then 240sx needs an adaptor to fit evo/sti brembos THEN I assume you need a bracket to bolt these babys up
08-19-2011, 10:19 PM | #6 |
Trader Rating: (63)
BTW. DO "SEARCH" first before making new thread.
http://zilvia.net/f/tech-talk/93748-...se-do-yet.html |
