![]() Join Date: Jan 2013
Electrical Issues
Right now my Headlights do not pop up ( if I press the button, they come up if I use the light switch). My windshield wipers do not work and the e brake light stays on.
For the e brake light, when the wipers did work. It acted weird with the light. If my wipers were up the e brake light went off but as soon as they were down the ebrake light was on, hence why my e brake light stays on because my wipers are down and won't move. This all happened exactly in one day. Just wondering if you guys had any idea. Sent from my iPhone using Tapatalk
Instagram: Nismo_Lk |
I have a similar issue. My lights don't go up & down, no wipers, turn signal switches make my entire cluster shut off. I pull the harness down in the driver wheel well and noticed about 15 wires were melted together. Saving for new OEM harnesses now.
#3 | |
Oh man I forgot that same day I was locked out my car so we used a wire through the door to unlock it. So maybe it's wires near the driver door that need fixing. Sent from my iPhone using Tapatalk
