![]() Join Date: Apr 2011
VLSD-50 Dolla or best holla
Hey spuds,
Got that phreshly used VLSD butt for sale still. Bought it off a guy on here a couple years back and can't trace the ad, but am almost certain it is from a pre 94' J30, but may also be from a 90-96 na z32. Ran this ass for about 2 years and it felt fine, however I would consider replacing the drivers side output shaft, since when my axle blew the last time it slightly gnarled the mating surface. Only reason I'm selling is cause I went back and shall remain welded for the time being. Does not come with axles and as you can tell require 5 bolt axles with these shafts. First one here with $50 retrieves the butt. ![]() |
#2 | |
GM2 (SW/AW)
You're positive this is a VLSD? like absolutely positive? does it have an ABS sensor on it?
I'm just asking because I've got the same back cover on a 6 bolt Z32 with abs but the internals are open diff. (Aka you can put an open diff inside of there)
Yessir, I am absolutely positive it is an actual VLSD. Doesn't have ABS, but my car didn't come with abs either. Drove on this diff for about 2 years, and did a good amount of grip/canyon driving and also drifted around with this diff a good amount the last year I was using it. Ain't no one wheel wonder for damn sure hahaha I'll try and post an old video of when I was first started busting some nuts out with the vlsd.
ALL PMS replied, going to go get some quotes on shipping today. I am willing to ship, just feel shipping rates may be a little steep due to the weight and bulk of the diff.
| diff, j30, lsd, s13, vlsd |
