Old 11-05-2006, 08:21 PM   #1
LovingMy240sx
LovingMy240sx is an unknown quantity at this point
ALTERNATER PROBLEM help help help!
my old alternator went dead on my 95 base model s14, so i got a new one but turns out that it is a se model with fog light alternator. it fits great but i dont know where to connect the the ground wire to the alternator. its different from the base model alternator and thats why i need ur help. thanks
the circle part is the ground wire. i dont know where to bolt that ground wire.
LovingMy240sx is offline   Reply With Quote
Old 11-05-2006, 08:26 PM   #2
s13silvia123
s13silvia123's Avatar
there should be a bolt in the back of the alternator where you ground. i think that bolt should be a 8mm nut.
Old 11-05-2006, 09:13 PM   #3
projectRDM
projectRDM's Avatar
Bolt it anywhere to the case, it doesn't matter where.
Old 11-06-2006, 07:01 PM   #4
O3DigitalBath
O3DigitalBath's Avatar
O3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud of
Send a message via AIM to O3DigitalBath
+1
it doesn't really matter, find anwhere on the case thats metal and put it on there...
O3DigitalBath is offline   Reply With Quote
Old 11-07-2006, 08:26 AM   #5
LovingMy240sx
thank you so much!
Old 11-07-2006, 02:40 PM   #6
projectRDM
projectRDM's Avatar
Originally Posted by O3DigitalBath
+1
The case is metal. Therefore, bolting it anywhere, to anything, is fine.
