![]() Join Date: Aug 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Ichiba woes.
In short, my wheel bearing went bad (rear passenger). So i got a four lug rear hub, got the bearing pressed out, and pressed back into my ichiba 5-lug hub.
So i got another. . same thing happened. But it doesn't seem to be working. I hear a sound coming from that bearing. It may be the guy that presses it, or maybe you are not supposed to press out wheel bearings. What should i do to get something that works, with a budget in mind. I need to fix this before the 13th (march madness) Thanks in advance, John.
Tacoheroi.com |
maxed out with all the collars with megan tracks.
I have not gotten an alignment. First wheel bearing broke because i had the car jacked up with a scissor jack and it failed on me. The rim slammed into the pavement, bending my rim, and breaking my bearing ( i'm assuming).
Tacoheroi.com |
