![]() Join Date: Aug 2010
Trader Rating: (43)
![]() Feedback Score: 43 reviews
SR20DET Partout - DocRace/PBM/Enthalpy
Prices - Pricing does not include shipping, if you're going to make me a shipped offer please keep this in mind. Some items have wiggle room while others do not, if you try and lowball me don't expect a response, simple as that. I accept payment via paypal, chase quickpay and cash for locals.
Shipping - I tend to ship smaller items via USPS Priority due to the cost, integration with paypal and location as I can drop the packages off on my way to/from work. Larger items will be shipped via FedEx ground, I do not ship via UPS. Due to my work schedule and the fact that I have to pick up these items from my storage unit it may take me up to a week to ship items, please be aware of this. Local Pickup - Local pickup is preferred, I'm out in brevard county. Warranty/Returns - All items are being sold as-is, I try my best to describe the item the best I can and I test the function if I'm able to, electronics are powered up and have pictures taken of them in a live state. If you have any questions about the functionality of an item please feel free to ask. Pictures - I'm getting pictures of this stuff as it comes off of the car, if you don't see a picture here that means I haven't taken it yet. OEM Bits - I have manifolds and brackets, if you don't see it for sale but know you need to to have a running SR20, I probably have it. Feel free to shoot me a PM. DocRace V-Band Manifold for SR20 W/ Turbine housing and Tial WG - 1300.00 Manifold is DocRace's OEM location manifold that is ceramic coated, manifold comes with Garrett .86 V-band turbo housing for GT28 turbos. Also comes with TiAL MVS gate and screamer pipe. This is a complete bolt on setup if you already have a GT28 series turbo. Garrett GT2871R .86 T2 Housing with Internal Gate - 900.00 Low milage and is in great shape, bolt on for S14/S15 motor sets or onto S13 motorsets with clocking adapters, whcih will be included for free if asking price is met. PBM Cobra Downpipe - 280.00 Downpipe is in great shape, works with the above manifold/turbo setup. Enthalpy Tuned SR20DET ECU - 400.00 Tuned for GT2871R/740cc injectors/Z32MAF/S4 Cams. Save yourself the downtime of sending out your ECU. ISR Turbo Lines - 80.00 S14/S15 SR20 Turbo Inlet + Outlet - 80.00 S15 Turbo Oil Drain w/ Hose- 40.00 ARP Headstuds - 80.00 Used but in good shape, one of the nuts is a bit gacked up at the top but the rest of the fastener is fine. JWT S4 Cams - 400.00 For S13 SR20 only, not compatible with VTC motors. JWT Adjustable Cam Gear - 50.00 Intake side only. Tomei Rocker Arm Stoppers - 50.00 Z32 N62 MAF - 90.00 Screens are in great shape and comes with a K&N Filter with adaptor. DeatschWerks 740cc Injectors - 375.00 Injectors are in good shape other than a little cosmetic marring around the plug when they were removed by the PO. Can include a OEM fuel rail with an ISR FPR delete fitting. Walbro 400 Fuel Pump 80.00 Used but in good shape, only has about 1800 miles on it. Wiring Specialties PRO Engine Harness - 500.00 In great shape, this is for a S13 SR20DET in S13 chassis with stock ECU. Has not been modified in any way. Comes with pigtail for Z32 MAF. Touge Factory S13.4 Valve Cover - 550.00 Professionally done by TF and powdercoated in red with welded on -AN fittings for the vacume/oil return for the block. Comes with AN fittings and lines to plumb back into the block and your intake. More about the service here - http://www.tf-works.com/tf-s13-4-hyb...rvice-sr20det/ Touge Factory Valve Cover Bolts - 60.00 Black in color and in good shape, comes complete. Invidia N1 Catback Exhaust - 300.00 Has a couple of dings and scratches but other than that it's in great shape. Local pickup only on this item. OEM Coilpack Covers - 30ea I have two of these, one in silver the other in black. TAARKS Power steering relocation bracket - 150.00 Comes with all hardware and belt. Relocates your power steering pump to where the stock AC compressor would sit for more clearance for turbo setups. ISR SR Ignitor - 60.00 OEM SR20 Alternator - 80.00 In good shape and works great. OEM Power Steering Pump - 80.00 In great shape and does not leak. ISR SR20 Replacement Starter - 125.00 Was purchased about two months ago brand new and the car just sat. Starter is pretty much new. SR20DET Transmission - 200.00 Comes with GKTech short shifter. Local pickup only on this item. HKS Hyper Single Clutch/Flywheel - 500.00 Clutch is in great shape with a ton of life left. Koyo Radiator - 200.00 Comes with ISR Radiator Hoses, fins are in great shape. Will need a new drain plug, the stock plastic one is stripped. Local pickup only on this item. OEM Radiator Shroud - 30.00 Comes with lower guard as well. Local pickup only. Moroso Oil Pan - 250.00 Used but in good shape, no dents or dings and includes all hardware for install. SR20DET Head - Offer Two of the cam cap bolts have been stripped out along with two of the valve cover bolts. Willing to take scrap value on this if you want to try and repair it. SR20DET Shortblock - Offer I also have the bottom end that is in good shape, engine had good compression but the above issues with the head led me to part out the car. If you're interested in the shortblock let me know and we can discuss price. CP Pistons Eagle Rods ACL Race Bearings ARP Rod Bolts Apexi Head gasket S14 Oil Pick up Last edited by hobbs; 07-14-2018 at 07:20 PM.. |
