![]() Join Date: Oct 2006
Trader Rating: (163)
New Brembo 4-Piston Calipers Front
I acquired these several years ago and kind of forgot about them in the basement after moving etc. They are brand new, however they incurred very slight damage to the finish while in storage. I touched up the areas and they are barely noticeable from a slight distance. As you will see in the pics, I also took closeups of the touched up areas. Brackets will need to be purchased from Brembo for your specific vehicle application. Or if you are talented then maybe you could make your own. I believe these will work with the 332mm rotors but you may want to double check with Brembo.
The part # for the calipers is: 20.8662.00 Asking $500 or best offer ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Broadfield; 03-01-2012 at 12:49 AM.. |
| bbk, brakes, brembo, broadfield, calipers |
