Surge Tank with stock s13 tank?
Has anyone run/seen a surge tank set up with a stock tank (instead of a fuel cell)? This would be for a drift car with 550hp.
Currently have in flow order- Walbro 255 in tank Walbro 255 in line just before engine bay Aeromotive Fuel Filter My stock tank is clean, no rust, etc. As I understand the rules- leaving stock tank in car I do not need to seal off the back of the coupe. Not that it is time consuming to do so, I just don't feel like cutting up my trunk floor and tubing everything at the moment. What I was thinking- Radium surge tank with external pump, mounted in spare tire well. I can move the inline Walbro to in tank for dual setup as well (probably not needed) or just remove it entirely. Any input on this? |
I have the stock tank and a surge tank setup in my S14. It would be no different in an S13...
You need a larger pump than the Wally if you want 550. Bosch 044 will get you there. If your going with the Radium setup, just get their in-tank surge tank setup. As far as rules are concerned, I would imagine that you'd still need a firewall/bulkhead built to pass inspection.
My SR20VET |
jr_ss, funny I just ran across your build thread last night and saw you put a surge on a stock tank.
Did you put fuel cell foam in your tank or just leave it as is? Bosch 044 is what I was going to order with the radium surge tank. Was going to ask them if I should swap out my Walbro for an intank bosch as well and Im assuming remove the inline walbro I have now as well. |
I left mine as is.
A Wally in the stock tank is fine, it is not your fuel rail feed pump anymore.
My SR20VET |
