Steering Wheel question - airbag
I've been searching and searching with no definitive answer on:
If swapping out steering wheels into the s14 from either the s14 JDM or the S15 will i get a blinking airbag light? Few threads have said functionality is there of the airbag but i also DONT want a blinking airbag light. It will just piss me off looking at it. Hope someone can shed some light. Thanks |
I'm looking for a more definitive answer, i mean i think it should work too but just want to hear from someone who has done it before spending 200 plus on a steering wheel...
Mine is blinking too, I just put in a new (used) clock spring out of my parts car so maybe it's not a good one. My horn works now but not using cruise control on my setup but I'm in for some input.
I have a 95 240SX SE with a S15 steering wheel, not sure of the year and I replaced my clock spring with a 95 240SX base model automatic clock spring, which had longer leads and would've required less cutting of the S15 steering wheel base for the clock spring to fit in position. I cut it out using the original clock spring. Not sure if the S15 AB would cause the blinking though.
Im thinking that the JDM S14 steering wheel, which is the one that looks like the maxima steering wheel should work and not cause a blinking light.
Lets say i installed one anyway to find out and the light blinks, then i remove it and go back to the original s14 steering wheel and bag will the light reset or will it think it was still incorrect? |
