1.5JZ Zenki build
Been running S13s for a few years. Figured it was time for a change.
Purchased a 95 S14 SE non ABS and no sunroof fixed a couple minor issues that would drive me crazy later if left alone things were done updated the headlights and threw on aero now messing with this this and fitting these currently waiting on parts to finish up fitting the motor so I can get the shifter extension done and driveshaft made.
![]() Last edited by S13project; 02-05-2015 at 10:16 PM.. |
finished up the front suspension bits
no more KA 1.5JZ test fit with Excessive brackets and Drift Freaq motor mounts after a good bit of waiting, the Quiksilver twin scroll manifold arrived
changing out the 17" original step lips Equips (not original specs at all tho)
to 18" meisters also. am trying to find a pair of USDM zenki headlights with good mounting points (that are under 200) so I can build another set of the chaser retrofit headlights and make a thread on the process. for now here's the couple pics i did take: all you need from the zenki headlight shaved down chaser headlight chaser guts in the zenki frame after everything has completely cured
![]() Last edited by S13project; 02-05-2015 at 10:19 PM.. |
Off to very nice and clean start....did buy those headlights or fully customized? Looking for a set of headlights myself....
***FortuneMinds*** 95 240SX S14 / 14 Lexus IS250/ IG / Twitter: juvi22003 |
#6 | |
Its the GT Rodeo Special (Rocket Bunny) bumper
one year later.....and nothing much has gotten done:
tubbed the front fenders thought this was the way it was going to go..... sold the built 1.5JZ and picked up these, all very similar specs, to fit with the ZG flares ....then this happened now need to sell all those wheels and pick up ones that will fit the TRA V2 flares without needing 30mm spacers.
#10 | |
If not those then I am not sure what you are asking about.
![]() Join Date: Nov 2007
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
Sorry my bad lol, I meant the zenki headlight housings for the chaser retrofit and do you have any pics of the back of the headlights after completion? Also how is the light distribution at night with them?
This is the housing without the plastic or chrome lenses:
This is all that was needed for the retrofit: Chaser headlight housing trimmed down to necessity: Glued and sealed Honestly the light output isnt terrible, but I would not want to be driving in the mountains at night with any rain or fog. The light is there its just not directed correctly. If/when I build another set I will more than likely retrofit a LHD correct projector setup into the chaser housings.
Trader Rating: (33)
Thanks for the info. I was considering this as an option if I don't retrofit my current headlights. I have jdm housings with clear lenses at the moment and the output is terrible lol. The chaser retrofit with proper projectors does sound interesting though.
#17 | |
Yea the V2 completely engulfs 18s. Almost considering 19s, but the cost per tire is damn insane. Maybe a set of 19s just for rollers, but stick with 18s for drifting. Always nice to hear we are getting love from the Atlanta community.
#25 |
![]() Join Date: Oct 2003
Awesome Build!
Loving the Trakyoto kit on this.
Performance Parts // Track Prep // Fabrication **Follow us on Instagram @TFWorks For all the latest TF★ news visit our blog!! ![]() |
#28 |
Currently building up the motor and making sure everything is nice and fresh while waiting on HKS cams. Picked up some new wheels that should fit the flares better. 18x11.5-30 rears. Still waiting on the fronts which will be 18x9.5-35.
One of the rears
