![]() Join Date: Oct 2003
TF★ Carbotech Brake Pads
Hey guys,
At TF we like to provide only the best products for your car and brake pads are definitely something you will want the best of for your car. Carbotech pads are used in many racing series and have helped many drivers win their races. They have a wide range of compounds front a range of street setups to race only applications. The best part about these pads, on top of the amazing stopping power, is how easily the dust washes away after a day at the track. I have personally used the XP8 pads on a BRZ and was amazed by the initial bite and the great peddle modulation I had with these pads. After a full day at the track the rotors still looked new and the dust just washed right off. Benefits: - Non-Corrosive pad material - High Heat resistance - Longer Rotor life Pad Compounds: - 1521 (street use only) - AX6 (street use / light track use) 50°F to 1100°F + - XP8 (track use / light street use) 200°F-1350°F+ - XP10 (track use / light street use) 200°F-1650°F+ - Anything more just PM me with what you are looking for. ![]()
have you tried the xp8 on the street? and have you tracked the ax6 personally? just wanting some input on these, might be a good alternative to the stoptech im ordering for my new setup.
