having an issue with my windows not rolling up or down. checked all the fuses which are all good and decided to try changing the relay but when i did still same problem.
could it be because my alternator is not working? both driver side and passenger dont work. did a engine swap awhile back and windows worked fine before and after swap it stopped working. |
