Old 03-10-2011, 09:28 PM   #31
Yesh
Yesh's Avatar
Location: Somewhere over the rainbow at long beach one rainy day.
Yesh is an unknown quantity at this point
Send a message via MSN to Yesh Send a message via Yahoo to Yesh
Is it this one??
NISSAN 240SX S13 FRONT & REAR 5-LUG CONVERSION SET - eBay (item 140506854527 end time Mar-31-11 03:47:21 PDT)
Yesh is offline   Reply With Quote
Old 05-19-2011, 08:44 PM   #32
twyztidmind
twyztidmind is an unknown quantity at this point
Yes thats the one.
UPDATE: When buying the ebay ones, buy some aftermarket studs such as ARP or Nismo. The ones that come with the hubs snap pretty easy.
I got some ARP Extended lugs since we are adding wheel spacers soon.
I have LOTS of S13 and S14 Parts, PM me!
twyztidmind is offline   Reply With Quote
Old 05-21-2011, 07:59 AM   #33
LDB477
LDB477 is an unknown quantity at this point
I am in the middle of doing one of these swaps and I'm running into an issue with the ABS ring. The toothed ring that comes off of the old hubs does not fit the new hubs, and the new hubs come with some weird flange-ring looking thing. I can only assume that this is some sort of ABS defeater, anyone else run into this?
LDB477 is offline   Reply With Quote
Old 05-23-2011, 10:33 AM   #34
twyztidmind
Can't help you there mine didnt have ABS.
Old 05-23-2011, 09:02 PM   #35
A54
A54's Avatar
Trader Rating: (40)
A54 is an unknown quantity at this point
Feedback Score: 40 reviews
Nice ...Thanks for the pictures!
A54 is offline   Reply With Quote
Old 05-24-2011, 11:11 AM   #36
Speed Junky
Speed Junky's Avatar
Speed Junky is an unknown quantity at this point
Eventually I will do this, i'm guessing you do this because a 5 lug is stronger and have more wheel options? Can anyone explain the technical side to this?
Speed Junky is offline   Reply With Quote
Old 05-24-2011, 11:20 AM   #37
fckillerbee
fckillerbee's Avatar
yes. brake options too.
Old 05-24-2011, 11:24 AM   #38
Edwin562
Edwin562's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
this will help me alot soon, i just bought my 5 lug hubs... thanks for great write up...
Old 03-20-2012, 02:31 AM   #39
Dany
Dany's Avatar
Dany is an unknown quantity at this point
Can I do the same thing as u but for an s13? or theirs more steps to it?
Dany is offline   Reply With Quote
Old 03-21-2012, 07:19 AM   #40
SuperDown
SuperDown's Avatar
SuperDown is an unknown quantity at this point
Sweeeeeeeeeet
SuperDown is offline   Reply With Quote
Old 03-21-2012, 07:32 AM   #41
jaysgottaredtop
jaysgottaredtop's Avatar
FYI for you do-it-yourselfers with access to a drill press and other basic tools:
#/f/s-chassis/400538...onversion.html
^ basically free front 5lug conversion.
Old 03-21-2012, 07:45 AM   #42
SuperDown
SuperDown's Avatar
I wanted to stay 4 lug pretty had but the huge selection of wheels and sizes is too much to ignore so screw it I'm down haha
Old 03-21-2012, 09:08 AM   #43
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
found it.
#/f/archive-faqs/142...pics-rear.html
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 03-22-2012, 09:16 AM   #44
jake schuur
jake schuur's Avatar
jake schuur is an unknown quantity at this point
good write up. I just did this swap and it was a breeze
jake schuur is offline   Reply With Quote
Old 03-29-2012, 02:17 PM   #45
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
^i'm with stupid hehe^
tapdeznutz is offline   Reply With Quote
Old 04-14-2012, 10:47 PM   #46
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
quick question for the guys who done this already, i'm in the middle of the rear swap and i couldnt get the four nuts by the spindle off. So i just pushed the spindle out! I removed the rear shocks and the suspison linkage then i used some man juice and pushed it out! Did I f#$% something up or is this a common thing?
lewisfk is offline   Reply With Quote
Old 04-16-2012, 08:11 AM   #47
lewisfk
lewisfk's Avatar
Noone has done this?
Old 04-16-2012, 09:50 AM   #48
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
push out? u mean removed the entire spindle? which shouldnt be a problem and you really did not have to remove ur strut either unless you just wanted more room to work....just remove and replace the 4 with the 5 lug hub now and re-assemble. i had to remove some linkages too but again everything is straight forward...just take ur time and think things thru. gl
Old 04-16-2012, 10:00 AM   #49
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
I have a questions. I bought some z32 n/a rear hubs. They fit my axEls and everything. But the hubs have he extra tab on them. Thoes holds the ebrake shoe together on the z32. Im bot doing the rear ebrake conversions so will these hubs work? Or are they only good for people using them for a z32 ebrake conversion? Oh and this is a s13 btw
Old 04-17-2012, 06:45 PM   #50
lewisfk
lewisfk's Avatar
Can someone verify the torque of the 36 mm hub nut is 75-85, and the four nuts are 58-72 lbs torque? Thanks Lou!
Hey guys im having trouble getting the rear hub off, is there something I'm missing?
The four bolts are off, the 36 mm nut and c. pin is also. I pulled to plastic rings from the inside of the 4 lug off. I spent the last hour banging the shit out of the hub, any suggestions!
Old 04-17-2012, 08:16 PM   #51
jaysgottaredtop
torque specs for the axle nuts are big-breaker-bar-and-jump-on-it.
torque specs for the four hub nuts are big-breaker-bar-and-tighten-it-as-best-you-can-in-such-an-awkward-space.
Old 04-17-2012, 08:18 PM   #52
lewisfk
lewisfk's Avatar
^^i have an impact gun so I can hit from 90 to 150 lbs, I just dont want to over due it! How about the other stuff I mentioned?
Old 04-24-2012, 07:25 PM   #53
cliffsmith1
cliffsmith1 is an unknown quantity at this point
So lets say I broke the front 19mm caliper mounting bolt... what size bolt would that be?
cliffsmith1 is offline   Reply With Quote
Old 04-28-2012, 10:47 PM   #54
lewisfk
lewisfk's Avatar
Hub puller works miracles! 20 bucks harbor freight!
Old 04-28-2012, 11:04 PM   #55
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Originally Posted by future View Post
I have a questions. I bought some z32 n/a rear hubs. They fit my axEls and everything. But the hubs have he extra tab on them. Thoes holds the ebrake shoe together on the z32. Im not doing the rear ebrake conversions so will these hubs work? Or are they only good for people using them for a z32 ebrake conversion? Oh and this is a s13 btw
+1, I also want to know this.
For Sale #1 | For Sale #2
Old 04-29-2012, 12:23 AM   #56
future
future's Avatar
Trader Rating: (42)
Ive been wanting a answer for months
Old 10-11-2012, 08:36 PM   #57
pacotaco345
pacotaco345's Avatar
It seems like the ebay hubs are hit and miss... My rear hubs have about 2500 miles on them and already have play on both sides. My front left hub came drilled slightly off center so it feels like I have an out of balance wheel all the time. My front right one though, is perfect lol. So just FYI for everyone, buyer beware.
Old 10-11-2012, 09:12 PM   #58
jesse_s13
jesse_s13's Avatar
jesse_s13 is an unknown quantity at this point
OEM. This can be a SAFETY issue.
jesse_s13 is offline   Reply With Quote
Old 10-11-2012, 09:40 PM   #59
jaysgottaredtop
^ both of my housemates (both with S13s) have used ebay hubs at one point or another, and they all went bad.
one hub (a front hub) developed play between the outer race of the bearing and the hub into which it was pressed! very very very very very bad. the bearing is bolted to the knuckle... but suddenly the hub/rotor/wheel are no longer firmly attached to the bearing! the only thing holding on the hub/rotor/wheel is the brake caliper (which is then getting loaded/twisted as the car enters a hard corner).
bottom line: ebay hubs can be very dangerous. either use oem s13/s14 hubs, or grind out a new snap-ring groove into a j30 hub and press in the correct s13/s14 bearing.
Old 10-11-2012, 10:36 PM   #60
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
j30 hubs FTW!!
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
