![]() Join Date: Aug 2008
Throw our bearing grease points?
Ok, I have been reading lots of different things on the web about this.
Where do you grease the TOB? I get it to put it on the inside lip where the unit slides along the input shaft and on the pivot ball. So you grease the actual outer lip of the spinning bearing? I mean in the grove of where the bearing spins and the outer wall. Do you grease the face of the bearing the meets the pressure plate? That doesn't seem right. |
![]() Join Date: Aug 2011
Do NOT grease the face o the bearing!!!
You should only grease the input shaft splines go easy with grease on here. You can use the clutch disc and slide it back and forth a few times so the grease spreads evenly. Also grease the tip(head) of the input shaft just a bit. You can also apply grease on the pivot ball, rear of the fork where it contacts the pivot ball. And ONLY on the inner lip of the bearing. Nothing else should be greased. Be very careful not to get the clutch disc dirty with grease or any thing else. Good luck |
![]() Join Date: Jun 2010
Was just doing this yesterday, here is the FSM procedure: http://www.nicoclub.com/FSM/240sx/91-94/CL.pdf
Grease where the clutch fork and TOB meet. Also where the fork and slave cylinder meet. |
#6 | |
Suffice to say Installed my first clutch last week and it wouldn't go into gear. No damage thankfully,but I had to pull again. Here's to doing it right the second time! |
#8 | |
I liken it to a bad slave cyclinder. But I also think the keeper spring in the clutch fork was not installed properly. Now I have the trans down and putting it back together and was just double checking evenything to make sure it 100% right this time. |
![]() Join Date: Oct 2010
same thing happened to me when i put in my stage 2 clutchmasters clutch. I ended up taking out the clutch dampener and adjusting the pedal and it finally went into gear with the car on. Thank god i didnt pull the tranny twice
