![]() Join Date: Nov 2003
240sx Xcessive front skid plate
Brand new skid plate from Xcessive Manufacturing. Fits any year 240sx from 1989-1998, s13 and s14 models. This doesn't clear my LS swap so i'm not going to use it.
Xcessive Manufacturing's front skid plate is cnc cut and formed from 2.5 mm thick steel then plated for corrosion resistance. We've designed the plate to bolt directly to the 240/180 chassis with no drilling or welding required. With all hardware supplied, this skid plate can be bolted on in less than an hour and protect your oil pan and engine for a lifetime. Designed to fit with stock and after market sway bars, stock and lowered engines, the plate has an off set rear bolting flange to help protect the bolt heads from damage as well as deflect debris from the cross member. Lowered your car or purchased one of our cast pans? Don't let your pan get damaged! SOLD
91 240sx 03 Pathfinder Last edited by 91 240; 08-26-2015 at 02:41 PM.. |
