5th gear - 3000rpm @ 60mph..??
Running a S1 rb25.. when i'm cruising at 100km/h (60mph) the rpms sit around 3k. I don't remember my sr running that high at that speed.. or am I trippin? Stock 240sx diff
Better yet whats your guys' rev range in 5th gear like? |
![]() Join Date: Jan 2012
I feel like my 5th is 3k at 70mph but I don't remember. SR, but I'm pretty sure it's a KA trans with SR bellhousing. Depending on which trans you have will change the gear ratio.
Na sr with a 3.9 j30 diff I'm at around 3500 @ 70 mph
![]() Join Date: Dec 2013
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
my sr with an sr trans a stock 240 diff(its a 2way, I don't think it matters though, ring is the same) is like 3k rpm @ 110-120km's. which as around 70mph at 3k almost 75mph if a little over
Time for a 6spd swap.
My SR20VET |
![]() Join Date: Sep 2005
Maybe I'm just an old head, but you build a car for its major use or purpose.
Then make changes as its use changes. Its like some of the threads lately are like... look at my pretty lunch. Should I try wasabi on it? I heard wasabi in your eyes burns, haven't tried that maybe tomorrow. What do you guys think? How many regular miles you got on it? None, it takes premium!
#8 | |
#9 | |
![]() Join Date: Apr 2011
JDMwhip
Swap in a J30 differential, it's a VERY nice difference and probably the best bang for your buck period after you're turbo. They're all VLSD's and I'm pretty sure all of them match our flanges. The axles are thicker and considered an upgrade, so grab those while you're there.. If you wanted WAY lower rpms the Q45 has 3.54/3.55 or 3.69 gearings depending which year you grab from. All of these are a bolt in affair and will solve your issue. The only thing I didn't like and want to remedy is speedometer error/inaccuracy. |
