Old 02-11-2013, 07:21 PM   #1
lil-red-89
lil-red-89 is an unknown quantity at this point
S14 fuel level sending unit wiring...
Ok so I just bought this 1997 Nissan 240 and when I bought it I knew the fuel gauze wasn't working but wasn't sure why. So today I pulled the top junction plate and lock ring off... Reached in the tanks and removed the fuel pump and sending unit ( what a pain in the ass!) so finally I get it out and see 2 things that automatically catch my eye. 1. There was a broken wire which looked to be a ground that was soldered to the side of what looked to be a resistor (black wire) and 2. There were 2 plugs for the fuel sending unit and only one of them was plugged into something, was this done from factory so the sending unit could be used for 2 different cars? I don't see this being the case.
Can some one tell me what the tan 3 wire plug is supposed to go to? The black plug goes to the bottom of the plastic circle plate, but the tan 3 wire plug I can't seem to figure it out? Thanks in advance...
lil-red-89 is offline   Reply With Quote
Old 02-12-2013, 07:00 AM   #2
lil-red-89
No one has any info?
Old 02-12-2013, 08:41 AM   #3
lil-red-89
this is the plug that I'm trying to find the connection for...
Old 02-16-2013, 02:44 PM   #4
lil-red-89
No one knows where this fucking plug goes too???
Old 02-16-2013, 04:30 PM   #5
MADE
MADE's Avatar
MADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant future
I just saw mine within the last two months, Im pretty sure I attached both connections. You couldnt find another harness in the tank?
MADE is offline   Reply With Quote
Old 02-18-2013, 10:09 PM   #6
lil-red-89
Well i found the harness, BUT still no fuel level....starting to piss me off quickly
Old 02-19-2013, 06:49 AM   #7
MADE
MADE's Avatar
DL the FSM and go to work.
It gives detailed instructions on DIY, Ill be sorting mine out next month.
Old 02-19-2013, 06:52 AM   #8
lil-red-89
Where can I download the FSM from?
Old 02-19-2013, 07:02 AM   #9
MADE
MADE's Avatar
google s14 JDM FSM
Old 03-20-2013, 07:42 AM   #10
lil-red-89
Ok got the FSM and it gives me no help on how to require or what wire goes were
Old 03-22-2013, 03:22 AM   #11
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Fuel Sending Units on S14 are notoriously bad. They either don't work, OR give's false reading...will say EMPTY when 1/4 tank of gas still left.
Best bet is to find someone local to you so you can look at the wiring in their car to see what goes where. If I recall correctly, the locking cap on the gas tank is supposed to be a male plug where the sending unit inside the gas tank clips into. You should see another harness outside the gas tank that plugs into the OUTER portion of the locking cap. If everything is plugged up as it should be, then you should be getting a signal out of the gas tank from the fuel sending unit PROVIDED the sender unit works AND the gauge on the dash board isn't burnt out / broken.
I hate troubleshooting electrical problems....they are always a pain in the ass!!
Good luck!!
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 05-06-2013, 01:38 PM   #12
D-KILLA
D-KILLA's Avatar
D-KILLA is an unknown quantity at this point
Send a message via ICQ to D-KILLA
I have the same problem,
mind telling me where you plugged this fucker into?
D-KILLA is offline   Reply With Quote
Old 09-28-2013, 08:18 PM   #13
taneal1
taneal1 is an unknown quantity at this point
'97 S14 - Remove SENDER UNIT from FUEL TANK
Originally Posted by lil-red-89 View Post
Ok so I just bought this 1997 Nissan 240 removed the fuel pump and sending unit
Hi There,
Can you tell me how you removed the sending unit? The fuel pump just slid out, but the sender doesn't move. The FSM says "slide it horizontally to the left." It won't budge.
Another site states that you have to remove a clip. I can't find any clip...
Tom
taneal1 is offline   Reply With Quote
Old 03-25-2014, 09:41 PM   #14
driftcars
driftcars is an unknown quantity at this point
Originally Posted by taneal1 View Post
Hi There,
Tom
I am having hard time removing it, too. Anybody know?
driftcars is offline   Reply With Quote
