![]() Join Date: Mar 2011
Car overheated now horrible knock started vid inside
Hi sr20det won’t stop overheating bleed system put dual fans drove around the block started overheating now it’s knocking if I put my ear to it sounds like top end took valve cover off all looks good here’s video https://youtu.be/ZQoJOgq71TA
![]() Join Date: Jan 2009
Trader Rating: (25)
You have a blown head gasket, possibly blew out the rings. When my hg blew I had no water in the oil. It would just constantly overheat. Didn't think it was the hg because the oil was clean and just kept trying to bleed the system more. Ended up blowing my ringlands out because of it.
Also that's definitely rod knock. Go ahead and pull the motor
![]() Join Date: Aug 2013
Compression test first, then leak down. Don't just start ripping into it, know what you're getting into first.
