#181 |
You're right, that is the best place for it to go. Any experienced cage builder will put it there.
#182 |
![]() Join Date: Jun 2009
Yeah for the question regarding licensing, I am probably running lap battle one more season and working on licensing as I can afford it.
Thanks for te confirmation on the cage. You guys had me second guessing for a min there. |
#186 |
love it!! its cool to see a build other then a drift car, very refreshing. looks awesome cant wait to see it when its done.
#189 | |
![]() Join Date: Feb 2010
15.6.11 Rear Braces The main hoop must have two (2) braces extending to the rear. The braces shall be attached as near as possible to the top of the main hoop, and no more than six (6) inches below the top. The braces must not contain any bends*. There must be at least 30 degrees between the plane of the main hoop and the plane of the rear braces. The main hoop rear braces shall be installed to form no more than a one hundred five (105) degree angle or no less than a seventy-five (75) degree angle with the main hoop when viewed from the top. The main hoop braces must be mounted at the rear shock mounts or suspension pickup points pretty sure the wheel well is not the shock mount or a suspension pick up I own a shop and i cage cars. I know the rules. the cross bars that are welded to that bar between the strut towers is not right either. A friend a mine right before i started doing cages got his car done by some ghetto shop got one similiar to your rear set up. Did NOT pass tech. Make the guy do it right.
S13 Coupe, S14 Kouki Crew Chief jeff Jones Racing |
#190 |
Why not quote the whole rule instead of the parts you are wanting to quote?
15.6.11 Rear Braces The main hoop must have two (2) braces extending to the rear. The braces shall be attached as near as possible to the top of the main hoop, and no more than six (6) inches below the top. The braces must not contain any bends*. There must be at least 30 degrees between the plane of the main hoop and the plane of the rear braces. The main hoop rear braces shall be installed to form no more than a one hundred five (105) degree angle or no less than a seventy-five (75) degree angle with the main hoop when viewed from the top. The main hoop braces may be mounted at the rear shock mounts or suspension pickup points (providing that the braces remain in compliance with all other sections of the CCR). They may go through any rear bulkhead(s) provided the bulkhead(s) is sealed around the cage braces. *There may be certain exceptions allowed for cars that cannot possible meet this “no bend” requirement. One exception is listed [Ref 15.6.11.A)]. Other exceptions may be made (not guaranteed) if all of therequired bars meet the specifications for a vehicle in the next heavier weight classification and the alternative design is submitted to the NASA National Office for special allowance. 15.6.11.A Rear Braces - Exceptions On cars where the rear window/bulkhead prohibits the installation of rear braces (Porsche 914, Pontiac Fiero, etc.) the main hoop must be attached to the body by plates welded to the cage and bolted to the stock shoulder harness mounting location. There must also be a diagonal bar connecting the top of the main hoop to the lower front passenger side mounting point (“Petty bar”). Some cars built for racing in other recognized sanctioning bodies may be granted a waiver of this rule, however they must show proof of compliance with the current published rules for their class. It does not say that it is required to mount to the shock mount or suspension pick up. It says that you can mount it there. The plates that are on there cover the rule. I have done my research and there is nothing on this cage that will not pass tech. |
#194 | |
you think it will. but it wont formula d and xdc base there rules off of FIA/NASA rules. there cage rules are direct copy of FIA/NASA rules basically.
#195 |
I have spoken with many people including a Continental Series Crew Chief and the Director of the Wasatch NASA Chapter. No one else has said that this design will be an issue.
I do appreciate you looking out for me though. Not trying to be an ass about it at all either, just saying thanks for that. |
#196 |
Well yesterday was extremely busy.
Basic schedule: Work: 7:30-1:30 Pull Engine from wrecked 240: 3-5 Pick up a trailer and head to cage shop: 6-8 Finish cage and bring home car: 8-12 But on the busy day was worth it. The car is now sitting in the garage, waiting for a new heart. |
#197 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Forget the crappy 90s car...more pics of that truck!
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#199 |
That thing is sickkkkkk.
Props on the SR power.
BRICKHOUSE PRODUCTS
#200 |
^Thank you sir.
I don't have more pics of that datsun. I will try and get some soon. I started cleaning out the interior today using aircraft stripper. I got a lot of it done, but i need to finish going through it all and then start painting. I also need to drill some mounting points for the lap straps on the harness. Oh and the SR20 went in today. Motor was pulled and new motor mounted in less than 10 hours. Long day, but totally worth it. Here are specs on the engine: About the engine. I had it rebuilt at Element with new rod bearings stock rods forged pistons new head gasket new gasket and sill kit new s14 SR water pump (better flow than s13 water pump) The head is stock but has new lifters stock turbine on the engine but aftermarket exhaust manifold and dump pipe braided oil and coolant lines stage 2 single plate clutch w/ ligthened fly wheel Engine has a little less than 5k miles on it since rebuild. Engine, tranny, wiring harness (wired for S14), ecu, mafs, ignitor, r33 gtr intercooler w/ piping, and full exhaust. Here are a few new pics of the cage, swap, etc. The engine needs cleaned up and the valve cover needs some love, but it is all in and solid. |
#204 |
Darren,
So few people run here that they combine classes a lot. I will probably just jump into whatever class is biggest so that they can get prize money into that class. I think that a class must have 10+ cars before they start contingency/ prize money. So for now, classing in the local nasa series should be fine. I will be running against most of my friends. Had I done the LS1 I would have moved classes though. I may be wrong about the way they run classes, though here. Either way I will fit in somewhere and have some fun! |
#205 |
Is the interior paint some sort of brush on paint?
BRICKHOUSE PRODUCTS
#207 | |
![]() Join Date: Apr 2010
That's cool, i've had some dealings with scca type rules here with AutoX (we have no proper road tracks around here) so i know that changes can adversely affect your class and make you less competitive, even though the car is faster |
