taurus fan...
So I installed my taurus fan and I am very satisfied with how much air it moves. However it uses to much power and makes my lights dim on my dash and idle a little rough. I have both high and low speed hooked up and only really use high in heavy traffic. The power wire is ran to my battery with a fuseable link and the ground is wired to my chassis. I have a 2 way toggle switch which controls high and low speed. Anyone know what i can do to fix this? Thanks Josh
O and one more simple question. I want to remove my ac. The belt i believe is connected to the water pump. When you delete the ac do you have to put a belt in between the water pump and the crank pulley or what. I have looked up many writeups but no one seems to mention this part of the mod.
