![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
So as my vehicle and myself progress, it unfortunately requires things to change over time. I'm adding a lot of my current parts up. They are already removed from the car and will not be getting anymore hours put on them.
- Everything was on the vehicle and used for 2 seasons (11 Events Total) - Everything is in Perfect Working Order TF-Works Ceramic Coated Custom SR-VE Dual Plenum Intake Manifold w/ Fuel Rail (no injectors included) - SR-VE P11 Head Manifold - Dual intake plenum design (equal air distribution) - Individual runner O-ring gasket design - Ceramic Coated Silver Manifold - Ceramic Coated Black Fuel Rail - 2 A/N Ports - 3 NTP Ports - Removeable/Changeable Throttle Cable Mount - PRICE - $1,150 Throttle Body - 90mm - Billet Aluminum - Anodized Red - PRICE - SOLD ![]() ![]() ![]() TF-Works SR20VE-T Turbo Manifold - Ceramic Coated - Twin Scroll - Used Twin 38mm Wastegates - T4 Flange - Dual Wastegate - PRICE - $990.00 ![]() ![]() Precision 5862 Turbo - Twin Scroll - .84A/R Turbine Housing - Ceramic Coated Compressor Housing - Ceramic Coated Turbine Housing - PRICE - $1,100.00 ![]() ![]() ![]() Tial Blow Off Valve - 50mm BOV - Black - Can Include Intercooler Pipe +$15 For Larger Shipping Box - PRICE - SOLD WedsSport SA55M - 18x9 + 20 (5x114.3) - 18x10 +18 (5x114.3) - WedsSport Center Caps - WedsSport Valve Stems - BRAND NEW...never had tires on them and have never been mounted on a car. - PRICE - $1,300.00 ![]() ![]() MAC Boost Solenoid - Terminated to a deutsch connector - PRICE - $25.00 ![]() CP Pistons SR20VE-T - 9.0:1 Compression - 89mm - PRICE - $320.00 ![]() ![]() ![]() Supertech Valves EX - +1mm Over sized Valves - 5 Angle Valve Job (Mazworx) - PRICE - $160.00 Supertech Valves IN - +2mm Over sized Valves - 5 Angle Valve Job (Mazworx) - PRICE - $160.00 ![]() Hydro Handbrak - Wilwood Master Cylinder - PRICE - SOLD Longacre Battery Disconnect - PRICE - $20.00 ![]() AEM Pencil Coils (4) - One went bad, but I don't remember which one - PRICE - SOLD RaceGrade Hall Sensor - PRICE - $90.00 ![]() PCI Race Hose - 4' Length - New/Unopened - PRICE - $18.00 ![]() HAWK Dash Warning Lights - 6 indicator Lights - Right Turn Signal - Left Turn Signal - Engine - Battery - Oil - Lights - PRICE - SOLD Coolant Inline Thermostat Port - PRICE - $10.00 ![]() Oil Cap - Nissan Threads - PRICE - $10.00 ![]() Cobb Access Port - Needs to be unlocked (Sold my WRX and forgot to unmarry the two) - PRICE - $30.00 ![]() JEGS Rear View Mirror - PRICE - $20.00 ![]() ![]() RJS Harness - PRICE - $70.00 ![]() EARLS Braided Line -PRICE - SOLD 350z Fuel Level Sender -PRICE - $20.00 ![]() 350z Doors -PRICE - $180.00 ![]() ![]() 350z Door Panels -PRICE - $80.00 ![]() 350z Master Cylinder -PRICE - $40.00 350z Brake Booster -PRICE - $40.00 ![]() 350z Front Lower Control Arms - 2 arms have SPL bushing - 1 arm is missing 1 SPL bushing end -PRICE - $60.00 ![]() ![]() 350z Front Upper Control Arms -PRICE - $40.00 ![]() 350z Dust Sheilds -PRICE - $20.00 ![]() 350z Door Sill -PRICE - $15.00 ![]() 350z Drivers Floor Mat -PRICE - $15.00 ![]() 350z Wheel Speed Sensor -PRICE - SOLD SR Upper Oil Pan -PRICE - $30.00 ![]() SR Oil Pump Gears -PRICE - SOLD SR Oil Block -PRICE - $15.00 ![]() SR Rear Main Seal -PRICE - SOLD
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 12-12-2020 at 08:13 AM.. |
Matt,
The oil pump gears, can you provide more information. Use, what pump(13/14/VE). How about the valves? I am assuming standard, not the shimless type?
My SR20VET |
| 350z, race car, sr20ve sr20det neo vvl, tfworks, turbo |
