Old 12-22-2008, 02:52 PM   #1
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
Removing Front Oil Cover (SR20)
Maybe I'm missing something but what all Hidden bolts am I forgetting.
I've removed the oil Pan (installing new Greddy pan) & UPPER pan and the 2-4 hidden bolts under all that.
I see 2 bolts under the valve cover (under the cam heads) - 1 I can access but You have to remove the cam (driverside) to get the other out???
Help - Thanks.
FSM shows you putting it on but not where ALL the bolts are for some reason.I'm thinking its just on there REALLY tight - though I think leaking somewhere.I want to re-seal it all!
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 12-22-2008, 03:17 PM   #2
projectRDM
projectRDM's Avatar
The two under the cams have to come out, no other way.
FORMERLY R240NA
Old 12-26-2008, 04:01 PM   #3
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
You can get the top two out without removing the cams.
Gotta get creative with your wrenches.
IIRC: The last one Id id, I actually used one of my fancy swivle sockets from harbor freight...not just a universal, but it's a universal socket in itself, with the socket in the end of it. Super compact and a great angle of attack persay...once you get it loosended, you should be able to remove it by hand.
