need help with ka24de
i have a 90 s13 with a ka24de swap i just did the timing chain and it starts up fine but then starts to miss and starts dumping fuel out the exuhast i noticed when i connect my battery number three injector starts clicking and i get no response when its runnining and i pull number three spark plug wire or injector wire.timing marks are on.what could it be.
1. You should post some pics of your CAMS with the motor at TDC....
2. Was the car already running and then you changed out the Chain? 3. Plug wires good?? you have spark in all 4? 4. Switch out the injector with another one or rotate the one injector to a different cylinder and see how if it works.... Good luck.... |
![]() Join Date: Dec 2002
Exactly. Test each cylinder for fuel and spark. Very easy to do.
