Well I got a KA24de for partout... I threw a rod through the block.. Before all that happened The Comps were 145 (Cold crank)... Basically the story of this engine... Used it to practice drifting.. At the time it pulled amazinly hard.. Main rod bearings started going out.. thus creating low oil pressure.. My oil light flickered on and off starving the engine for oil up top.. Started hearing knock while driving with the oil light on (Stupid i know) and ended up with a thrown rod.. Everything on the engine is up for grabs as partout or selling it all
Offers plz LMK what you guys need... Willing to ship Need money to help fund my SR swap Pulled outta a 91 SE 248K Miles *Head has been rebuilt at 220K before thrown rod *Maintained with 20w/50 synthetic oil *AC Comp works AMAZING GOOD... Everything is stock *MAF and Ignitor coil up for grabs *Sub harness for Speed sensor *Tranny Works like new.. Barley and play with shift... No gears grind... Trans Flush done 6K miles ago *LMK what u need. *Intake Box and stock Plastic piping with filter forsale aswell.... New Napa Filter XD *Complete Fan Shroud no cracks *After Market fairly new Radiator with cap *Brand new starter... Really cool has tabs to run a switch to crank it... Basically that means u can turn ur car on to the ON position and start ur car with a switch (Good if ur starter relay is Effed up.. or have ignition problems) *Distributor - 30 picked up + 7 Shipped works great Car did idle perfect with Distributor Cap *Cam shafts S13 91- 15 each *Let me know what Sensors u need - PM me for quote *All internals up for grabs *LOL Oil Filter with like less than 10 miles on it - FREE Pix of the engine and Damage:
Pissing Off Daily Commuters Last edited by Crazian609; 12-21-2008 at 09:22 PM.. |
hmm 20 Picked up..... Shipped ill have to quote u with ur Zip code... But if ur local Ill deliever.. Its clean... Ill throw in that little Air breather to
Pissing Off Daily Commuters |
interested in the tranny and any 5 speed swap parts you may have if still available. will pick up. email me at [email protected]
#11 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
im not bashing just some advice, if your oil light ever comes on. shut the car off right away and dont run it at all til you fix it. saves alot of trouble later.
![]() Quote:
#17 | |
Posted from Zilvia.net App for Android |
| ka24, ka24de, partout, s13, s13 partout |
