Stock head bolts NOTE: Stock head bolts only. There is an order of sequence (see picture) 1) 29Nm (22ft-lb) 2) 78Nm (58ft-lb) 3) Lossen all bolts completely 4) 29Nm (22ft-lb) 5) One of the following: With angle wrench: 80 to 85 degrees clockwise With torque wrench: 74-83Nm (54-61ft-lb) Girdle NOTE: There is a order of sequence (see picture) 1) 46-52Nm (34-38 ft-lb) Rods NOTE: There is a tightening sequence 1) 14-16Nm (10-12 ft-lb) 2) One of the following: With angle wrench: 60-65 degrees With torque wrench: 38-44Nm (28-33 ft-lb) |
