Old 08-14-2008, 08:39 PM   #31
corymaloy
corymaloy's Avatar
corymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to allcorymaloy is a name known to all
Send a message via MSN to corymaloy
s13
Originally Posted by Propaganda View Post
I don't know where you got that bolt to put in there, but mine has both sides threaded
Both sides are threaded so that you can torque both of the bushings in place. The way I saw it is that you only had it torqued on teh bottom
well its an aftermarket sway bar, that might be why. I have no idea what brand or anything because it was on there when I got the car.
corymaloy is offline   Reply With Quote
Old 08-14-2008, 08:50 PM   #32
corymaloy
corymaloy's Avatar
s13 progress, kinda
ok so, I have all the broken stuff out... welll kinda. In the process of taking out the tie rods I found power steering fluid in the boot, meaning its leaking. Prior to my accident I was having problems witht he power steering so I'm guessing this wasnt a result of my wreck. I have been told I can leave the leaky rack in and just turn the wheel harder or replace the rack. Since im low on money I want to get my wheels movin again then I can replace the rack later, does this sound like a viable option??? also... the end of the rack is jsut sitting without a boot... should I put the boot on temporarily till I get the tie rods?
Old 08-14-2008, 09:16 PM   #33
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
NVM, you got the ball joint out already...
My SR20VET
Old 08-15-2008, 12:53 AM   #34
aznpoopy
aznpoopy's Avatar
aznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond repute
Send a message via AIM to aznpoopy
i don't think it matters. but if you're really that worried, just put a plastic bag over it and secure it with like a rubber band or something. no need to put the boot back on... plus the boot has a big hole on the end anyway.
yeah you can drive on it that way. just disconnect the belt. i would personally just buy a replacement rack. they are like $300 rebuilt after core refund. really not that much money. do it now and save yourself the trouble of getting the car up and taking shit apart again.
aznpoopy is offline   Reply With Quote
Old 08-15-2008, 07:29 AM   #35
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
If your rack is leaking your powersteering will be affected. When you turn you will notice the its smooth then stiff and so on. If you have the funds, replace it since your already taking out the tie rod. If you do, get some new poly steering rack bushings, either Nismo or Energy Suspension. I would order some new sway bar endlinks from Nissan or if you want get some aftermarket ones.
eek is offline   Reply With Quote
Old 08-18-2008, 10:20 AM   #36
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
Originally Posted by corymaloy View Post
I have unbolted the tension rod and LCA but I cant seem to get the LCA ball joint disconnected from the hub... any ideas?
You probably will have same issue with a tie rod.
Hammer is the answer.
But don't hit the thread on top.
Hit the spindle.
Sir is offline   Reply With Quote
Old 08-18-2008, 02:50 PM   #37
corymaloy
corymaloy's Avatar
s13 Ball joints
So is there a trick to installing the new LCA? IDK anything about the ball joints, do I just tighten the nut or wat...
Old 08-18-2008, 03:31 PM   #38
Sileighty_85
Sileighty_85's Avatar
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-18-2008, 05:40 PM   #39
aznpoopy
aznpoopy's Avatar
you only need a press (or a ghetto press - see above) if you bought the ball joint seperately from the lca.
if you bought them as one piece, just install and tighten. don't forget the cotter pin.
Old 08-18-2008, 10:52 PM   #40
1slowS13
1slowS13's Avatar
1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice
yep, the lca you got has the bushing pressed in, just install and tighten.
1slowS13 is offline   Reply With Quote
Old 08-20-2008, 11:53 AM   #41
corymaloy
corymaloy's Avatar
s13 I got the stuff
Ok guys, well I have all the parts now, finally! cant expect much for $7 shipping.. anyways now I just need to put everything back in, I'm just trying to figure out the best order of putting it all back. Also people keep saying something about making sure both tie rods are the same distance, what do they mean, and how do I make sure they are?
Old 08-20-2008, 12:11 PM   #42
aznpoopy
aznpoopy's Avatar
i think they mean try to keep your tie rods the same length as they were before so your toe isn't totally fucked up. but your old ones are broken and your toe is probably going to be fucked regardless.
just eyeball it the best you can after you're done fixing it and get it aligned at the closest decent shop you got.
Old 08-20-2008, 01:23 PM   #43
S14DB
AFC #1
S14DB's Avatar
1) Lower Control Arm
2) Traction Control Rod
3) Tie Rod
4) Tie Rod End
5) Sway bar End link
Old 08-20-2008, 07:37 PM   #44
corymaloy
corymaloy's Avatar
s13 I whacked it
so I beat the hell out of my old LCA to get all the nuts/sway bar endlink bits out.
Old 08-20-2008, 07:50 PM   #45
1slowS13
1slowS13's Avatar
so is it done?
Old 08-20-2008, 07:57 PM   #46
corymaloy
corymaloy's Avatar
s13 ummm
no its not done, im workin on it... but I think its about to rain and I have no cover... :\
Old 08-20-2008, 08:08 PM   #47
aznpoopy
aznpoopy's Avatar
men work in the rain. get her done
Old 08-20-2008, 08:34 PM   #48
corymaloy
corymaloy's Avatar
s13 fine fine, I will work in the rain
ok guys, LCA has been installed, heres a pic.... tell me if it looks like a f*cked up!
Old 08-20-2008, 10:03 PM   #49
1slowS13
1slowS13's Avatar
looks fine, mount it up and take her for a drive! it feels okay, get her aligned
Old 08-21-2008, 01:04 AM   #50
corymaloy
corymaloy's Avatar
s13 ummmmm
welll after I made that last post, I tried to connect the tension rod to the LCA and had some trouble, it looks like something is tweaked. I think the crossmember that holds the LCA is shifted back just a little bit. There is about a half inch difference to where the holes are and where the bolts on the tension rod are. I'm not sure what to do. I think I might try to shift the crossmember and tension rod bracket around till things line up, but its gonna be a pain in the ass! Not to mention I dont know if the tie rod will line up right. I will give it a shot tomorrow.
and also, you guys HAVE to see tropic thunder... its so funny!
Old 08-21-2008, 09:55 AM   #51
S14DB
AFC #1
S14DB's Avatar
bolt the TC rod to the LCA. Then pull it forward to the bracket. Would not be surprised if you have to bash the cross member a little bit forward.
Old 08-21-2008, 01:24 PM   #52
corymaloy
corymaloy's Avatar
s13 im dumb
well guys, I dont know why I was having trouble before, this morning I went out and put the LCA and tension rod in, no problem. (I had them bolted together before installing)
The thing is, take a look at the tension rod where it connects to the tension rod bracket, it looks twisted! I dont know if its supposed to look like that... But when I looked at the other side of the car it was the exact same way... This 240 was wrecked a looong time ago before I owned it and I think they welded a new front end onto the car, so it may be related. anyways I dont know how long the bushing in the tension rod will last....
Somone tell me if this twisted look on the tension rod is supposed to be there please.....
thanks!
next up, tie rod!
Old 08-21-2008, 03:03 PM   #53
S14DB
AFC #1
S14DB's Avatar
It's twisted cause it is at full droop. They twist as the LCA goes though it's motion. It will look more normal on the ground.
Old 08-21-2008, 09:20 PM   #54
corymaloy
corymaloy's Avatar
s13 wow thanks
I dont know why I didnt think of that... wow talk about a newbie...
anyways so im trying to install the tie rods and I can't find any information about them anywhere in any of my manuals... its kinda strange...
so anyways I took the broken one off and now im installing the new one. I'm worried because I dont know how hard im supposed to torqe it into the rack, if at all..
Also there is this clip that used to fit the old tie rod but doesnt seem to work with the new one, I dont really know what to do with it. you can see it in this picture, I can tighten the tie rod in, but the clip keeps it from being fully threaded in.
I was curious how the clip had fit originally so I looked at the other side, here is how the clip is supposed to fit.
I'm not sure if it even matters, right now Im thinking about just screwing it on there as far as I can and throwing the boot over it, let me know if you have any insight on this!!
Also, just for the hell of it, here is my engine bay! lol
Old 08-22-2008, 01:45 AM   #55
corymaloy
corymaloy's Avatar
s13 ....
ok so I downloaded like 5 shop manuals before I finally found any info on that little "clip". Looks like its called the "lock plate" and it doesnt seem to fit my new tie rod.... also, as you can see in my last post, the pictures from one side to the other look different where the tierod enters the housing, it looks like there is a piece missing. im pretty sure its called the "End Cover Assembly". if my car drove without it before then its gonna continue to do so until I have someone put a rack in it for me.. lol
bahhh its late, im tired, I need to look at things again in the morning before I start making crazy decisions... lol
Old 08-22-2008, 01:51 AM   #56
jdmstatuS13
jdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura about
dude i replaced my OE tie rods wih the tein inner and outer...u dont even need that locking plate...
u will be fine and im glad u got most of that crap fixed. haha
jdmstatuS13 is offline   Reply With Quote
Old 08-22-2008, 09:16 AM   #57
aznpoopy
aznpoopy's Avatar
u dont need the lock
but at a minimum, it wouldn't hurt to put some lock tite on the threads
Old 08-22-2008, 12:12 PM   #58
corymaloy
corymaloy's Avatar
s13 worried
I'm a little worried about the "End Cover Assembly" that I mentioned earlier, you can see in the pics, it like the cap at the end of the rack, and im assuming it olds all the fluids and shit in there... But when I took the boot off there wasnt one there (there was on passenger side, just not driver side) and I cant seem to find a replacement... Im guessing it comes with a new rack which im planning on getting in about a month. But i just feel uneasy about sealing it up knowing its wrong...
what do you think?
Old 08-22-2008, 04:49 PM   #59
corymaloy
corymaloy's Avatar
s13 Tie rod problems
ok so, according to my manual, there is supposed to be a nut at the end of the outer tie rod.... im guessing it tightens it somehow... well my new one doesnt have one of those.. There is one on my old one but the thread is bent. anyways heres a few pics to show you what I mean.
Old outer tie rod...
New outer tie rod....
pic of the manual....
What shall I do?
Old 08-22-2008, 05:42 PM   #60
S14DB
AFC #1
S14DB's Avatar
Yeah most assume you are reusing the old nut. Get a new nut.
broken, owned!
