I did some research a few forums around. can u help me some infos or advices?
i installed tein ha on my s14. front wheel is 18x8.5 +35 offset. what should i get it fixed? 1.5 inch wheel adapters? how big? thin spacers wont solve problem. wheel aligments? see the pic of that coilover hitting right tha where the wheel/tire meet. |
![]() Join Date: Dec 2006
More negitive camber or a 15-20mm spacer
not sure on your coil overs but quality coil over have Camber plates on the top held on by 4 allen screws, raise the car up a little, loosen the screws and move the coil over to the inside of the engine bay for Negitive camber
Bolt on spacers, no need for longer studs
Seriously?
What makes you think thin spacers won't solve the problem? From the picture you posted it looks like your wheel is bolted on and touching the coilover. A thin spacer should do just fine. Set of 2 / 4x110 4x4.25 4x108 4x4.5 4x114.3 1/4" 6mm Wheel Spacers | eBay
#13 | |
![]() Join Date: Mar 2009
10MM @ the least, when I had +30ish battles that were 9" wide I added a 30MM spacer and with a little bit of negative camber and a 225 45 17 Tire the fitment was perfect, with stock s13 fenders. My set-up was a little extreme though I believe my camber was 3.5-4.5. Judging by your wheels you would need atleast a 15MM to be genuinely happy. GL.
Guys, unless his top bolt hole for the spindle is oblong, cambering in his coilovers isn't going to help. That just pivots the wheel and coilover together as a unit... He needs spacers or if the top hole on his coilover is oblong, to loosen the top bolt on his coilover/spindle, pull wheel out and tighten down. Then adjust camber from there.
My SR20VET |
Oh damn, so your already on spacers? just get some 25mm bolt-ons if your fenders will accommodate them.
or 20mm slip-ons with extended lug nuts. Realistically though, you should just get better fitting wheels. Your sizes aren't really modified S-chassis friendly. Goodluck
ok I'll do more negative cambers tOmorrow in da morning. If fails, Then buy a pair of 25mm. Thats it! I don't wanna change longer studs. My friends said I should buy another set of wheels under +25 offset, that problem wud b solved.
#20 | |
Man w/ CTSV & a Car Seat
But the kicker is, he cant loosen the spindle since it wont do anything, doesnt look like those teins have slotted mounting holes on top. |
#21 |
You don't have to spend money on new wheels. A +30MM or more is not a very good offset but you can change your offset by getting spacers, getting a 25mm or 30mm spacer will bring you back towards zero offset. It is simple as that. Getting a 30mm spacer will leave you with +5mm offset, giving you a very solid normal set-up, that will not rub against your coilovers. Even a 25MM spacer would help you indefinitely and push it to +10MM. Since you have 8.5" wheels you are probably running anywhere between 215 to a 235. Stick to a 45 series and stay in that range of width. You won't have any issues.
#22 |
You're friend is right...shitty wheels are shitty wheels. Sell them to some honda kids, save the money you'd spend on buying spacers and buy better fitting wheels. Look in the wheel fitment thread to get an idea what people are running.
