03-09-2010, 01:27 PM | #1 |
AEM Base Map
Looking for a base map for a KA that is NON-turbo at the moment. Using AEM 1610 on 95 ODBI 240sx. Any help appreciated. I can also switch over to AEM MAP sensor and Air intake temp sensor if base map is avalible as I have the sensors already laying around.
Any help appriciated. |
03-09-2010, 01:45 PM | #2 |
why not just get a stock ecu unless you got a ton of n/a mods to the car? I highly doubt that there are much if any one with a stock or n/a ka running an aem emu and if they did, it probably wont be as good as the stock ecu. Just my opinion.
03-09-2010, 01:55 PM | #3 | |
Furthermore .... AEM tunes often are an improvement over the stock ECU. I also have a number of mods and more to come. MDS SCI and blaster coil. Cat-back UEGO wideband Clutch Fan delete (electric fans added) I know its not much now but here is some what is coming soon. Basically .. this is to get me started on the tuning and work out bugs. |
03-09-2010, 02:05 PM | #4 |
how about using your stock ecu until you install everything? Slap on aem emu afterwards, contact steve shadows about getting a base map (not free by the way, but not expensive either). Then you can try and fine tuning it yourself.
03-09-2010, 02:06 PM | #5 |
How about you let a guy in on how I can contact Steve Shadows so I can do it now like I want to? The SCI and EUGO made the car a lot more responsive and I would like to see what a tune would do for it as it is .... baseline numbers are always good.
03-09-2010, 02:22 PM | #6 |
look up steveshadows or go to the dyno faq and pm him from there. Everyone on zilvia knows (or should know) who steve shadows is.
EDIT: Also forgot he is an a vendor/advertiser for zilvia now. |
