LS Swap - Intake Manifolds?
Hey guys, I recently purchased an S14 that has an LS turbo swap. I was curious on which intake manifolds guys were able to make fit under the stock hood?
Currently the car has a sniper intake/throttle body. Id like to get rid of it and either go back to a stock truck style intake or possibly the TBSS intake. I had considered the BTR equalizer, but its intended RPM range is 6-8000. For street friendly car, I think this would shift the power band a little to high. Thoughts? |
Well to be honest, it’s a weiand aluminum intake which weiand is owned by holly. You can see photos in my build thread.
Dont be a pussy...Leave your name |
Any truck/SS manifold is going to be too tall..
Usually everyone does the LS1/LS6 manifold. Its affordable and clear the hood without any issues. But performance wise, nothing flows better than a truck/trail blazer SS I/M. |
#6 | |
So basically its limited to car manifolds, holley sniper and weiand. Possibly the BTR equalizer but ill need to compare the dimensions against the sniper. |
