power windows
hi i have manual windows and want to convert to power windows. the car i have now that i'm trying to fix up is a base model. i have another car that is se model which has power everything. the se model is junk so what's the easiest way to do this?
![]() Join Date: Dec 2002
Searching for the answer is the easiest way since we've covered it two dozen times before. You do realize that it's 20 years later, people have talked about these cars before in detail.
ill give you the quick answere. since i have the same and i searched and this is what i got from it. the base model has no pre-wiring in it at all so there is no plug and play. if you have a parts car with the pwr options. then take out all the door wiring, window motor etc. swap it in to yours then you have to run your wires to the other side and for power tap it into your acc wire and rig it in as that will be the only way unless u completely strip your dash and swap entire car harness with the pwr one fuse box and all.
someone correct me if im wrong but that is a quick jist of how to, theres a decent write up here some where that says what wire is what. |
