s14 sits lower on driver side
Anybody else experience driver side sitting lower after coilover install? I have power by max suspension and also installed solid subframe bushings thinking those might be worn, but nothing. Its like 3/4 of an inch higher on passenger side.
![]() Join Date: Sep 2009
Try adjusting your suspension like txredxj said for some reason i had that issue to but with my s13 my first though was also worn bushings but never really looked into the issue just raised the driver side a bit that was all.
VVVV THAT TOO! |
![]() Join Date: Nov 2006
Could be a number of things from:
-worn bushings -damaged chassis -incorrectly adjusted coilover -bent suspension -low tire pressure the list goes on...
![]() Quote:
