Guest
Posts: n/a
ok well after i get teh s13 sr20det motor installed what do i do next? I mean like except for the basics like exhasut and intake which is obvious what should i do?
![]() Join Date: Jul 2001
If I did the swap i'd leave it stock for atleast a month to be sure it run's good, and no problem's arrise, everyone else can tell you a mod list but I think you need to do that first.
like the ca18guy said run it for at least a month first, then you can start with fuel pump, blow off valve, larger intercooler. then you can get a boost controller to run it at 20pounds and you will blow something a way, if not maybe your head will. hehehe have fun man.
Guest
Posts: n/a
how will those help each?
