![]() Join Date: Dec 2009
sr20det using z32 maf (easy question probably)
when upgrading turbo setup and upgrading the maf sensor does the z32 maf need to be from a twin turbo 300zx or is the N/A maf ok or the same one?
also ebay has aftermarket mafs for $25 should I only get OEM when it comes to this or are these just as good? https://www.ebay.com/itm/Mass-Air-Fl...8AAOSwy7lc0-lS |
#2 | |
![]() Join Date: Jan 2013
Instagram: Nismo_Lk |
+1 I got lucky that martin from enthalpy was able to get my autozone one working, it was still not quite correct, the scaling the non OE ones use is a lot different and inconsistent
