![]() Join Date: Jan 2008
JWT Adjustable Cam Gear Setup (KADE)
I recently purchased a KA from a friend of mine. The motor is freshly rebuilt and has Tomei 270 Poncams. Other than that its essentially stock. Tomei calls for adjustable cam gears when running these on a non-turbo application so that's what I'm planning on doing. JWT is the only manufacturer I've found for these on the KA. If there are other choices I'd love to hear about them. Mainly though I'm looking for proper setup instructions with these. What tools are needed, proper procedure for setting them up, etc. For now its just going to be run as N/A, criticize that if you want but that's where I'm starting with it.
Also, if you're currently running these cams or cam gears and do not like them, I'd like to hear about that too. Thanks in advance.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z -Shake N' Break Racing- |
![]() Join Date: May 2005
![]() ![]() Feedback Score: 2 reviews
JWT is the only option for adjustable cam gears on the KA as far as I know. Go over to ka-t.org and search "cam timing" I'm sure you'll find everything you need there.
