Rb25 s2 running very rich an no power
I have an rb25 in my s14. stock turbo, isis intake manifold, big front mount, q45 throttle body, open exhaust and downpipe with a Mines ecu. Recently replaced the plugs, oilchange, and an over all visual check up. I bought this car in april with all these mods and all the work already done. I havnt changed a thing accept what i've mentioned engine wise.
Tonite as I was driving somewhere I decided to light up the tires get the car a little sideways, nothing big really but as I straightened out the car died. I cranked it back up and it didnt want to stay idle. I give it some gas and decide to just start going cuz the car does this from time to time once warmed up. As I start to go I can only barely hit the gas without it bucking and sputtering ( basicly running terrible ). when I pull over in a parking lot I turn the car off, collect my thoughts then cranked it back up. It barely wants to idle but it will and I walk to the back of my car and I smell gasoline bad and see a bunch of black smoke. I go under the hood and nothing visibly has changed. I'm really not sure where to begin. I went back earlier after searching the forums for ideas. I tried to crank it and it seemed to run fine for about 1-2 secs then died. Cranked it again and it was back to the way it was. I know one thing is for sure that the new spark plugs I put in were gapped to .28 as I always have done but I'm pretty sure after the short trip to that parking lot after this occured that I need new plugs or need to clean these. It was sending black smoke out the exhaust and the smell of gasoline very strong
