hey whats up guys im swapping th8e sohc motor into my 95 and was wondering do i0 need to use the s13 wire harness or will mine be the same? i need info asap so any help is good thank you
well long story short i bought it with only a block i had 3 sohc motors laying around and decided id rather have a car that moves than not also i like when the sohc are turboed any info on the wire?
![]() Join Date: Dec 2002
That's a lot more trouble going that route, you'll use the S14 harness since it's a bitch to redo the F3 plug but you'll have to cut the injector clips off the SOHC harness along with the TPS, CTS, and whatever doesn't match up.
