J30 VLSD on 4 lug S14
So far I know everything else will work, but will a J30 VLSD work if the car is 4 lug? Is there a difference? I know it's a 97 J30, and I believe I'll need two upsized bolts for it, but that's no biggie.
![]() Join Date: Jan 2007
im not sure with what years j30s but its the output shafts (6 bolt/5 bolt) that will determine if itll be direct bolt on. im in the process of looking stuff up on j30 vlsds because my welded is annoying me
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
![]() Join Date: Dec 2002
Wow. No. The hub is different, not the axle. Two completely different things. The diff is a direct replacement with no additional parts. Where ever you're researching, quit.
