![]() Join Date: Mar 2005
1st SR oil change
I decided to change the oil in my Redtop SR20DET. I drain the oil and everything is fine untill I realize where the damn oil filter is .
I then think this will be easier perhaps if I get under the car and try and grab the filter...wrong. The oil filter is mounted in the dumbest spot and almost impossible to get to and then for some small miracle you do get the oil filter lose, oil is now dripping all off my engine. Is this just because I have no clue what I am doing? I have never seen a oil filter in a more annoying place and who the hell mounts their oil filter horizontal to the motor? Any tips for getting this done w/o making a mess?
Linux System Administrator rm -Vfr /etc/*nix "Love is a fist"
AFC #1
![]() Join Date: Oct 2003
Remove the intake brace from the bottom of the intake to the block. This is right next to the filter and makes changes a bitch. You can also get a greddy intake to make more room.
If it's really a pain get a relocation kit. |
get a long ass screw driver and hammer it through, then turn it as much as possible. Keep trying, eventually, you'll get it.
Taking off the manifold is for pussies! Once you get it off, be sure not to overtighten the new one. |
#4 | ||
Ok, I have a Greddy intake manifold on the way so I hope this will make a big difference.
Thanks for the info.
I did not forget, I just don't know. What exactly needs to be modified to get the Greddy manifold to work? Every thread I searched in said nothing about modification at all.
This is the most backwards thinking I have seen in a while. You have trouble getting an oil filter off so you decide to buy a $400 intake mani that will be much more of a pain in the ass to install than replacing an oil filter.
Also, you complain that it's going to leak on your engine but the greddy intake mani you ordered isn't going to help in that respect. You are still going to leak oil all over your engine mounts when you change your oil in the future. You should have just ordered a oil filter relocation kit for $150. |
#10 | |
I was simply stating that the oil filter is bound to leak when you losen it as it is mounted horizontally. So because the oil filter is in a hard to reach spot, I should never upgarde my manifold? The fact is the oil is changed and it can be done w/o wasting $150 on a relocation kit. socal -1
#12 | ||||
As somebody said before, take off the stupid intake manifold bracket, get a filter wrench adapter from autozone or wherever, and simple green the area that you spilled oil. |
![]() Join Date: Jan 2004
How about you just get some brake clean and rags? They usually work pretty well.
I'm from Florida so I'm probably a bit more strange than you |
The thing to remember is to not overtighten the filter. It becomes much easier once you start doing it yourself and not some mechanic who insists on using a wrench to permantly affix the filter to the block. Having it just snug enough to stay on will alleviate most of your headaches.
#17 |
Yes, sprayed down the block with brake cleaner and looks nice and clean for the time being. Now the manofold is off and I was able to get to the mess I made much easier.
The trick for me is getting the filter loose and then quickly tiping the oil filter up so nothing else spills out. I have never seen a side mounted oil filter or I guess I am just to use to the 3SGTE motor. Anyways, I am sure by my 3rd oil change I will be a champ. I just have a lot more shit on that side of the car than people realize since it is RHD. Power steering pump and res plus all lines and housings are right there, no to mention the huge alternator does not help. Thanks for the info.
#19 |
The GReddy intake manifold will require a throttle wheel off an S14 SR motor (which jspec carries) as well as a custom throttle bracket, I think some bending w/ the fuel rail, and possibly a few other things I am forgetting. It's definitely no picnic to install...
#21 |
To take the filter off, use one of those cap-type oil filter things that attach to a rachet and a long extension.. easily found at any auto parts place. As far as spilling oil all over the place taking out the filter, not much you can do about that. I just place a lot of newspapers underneath and go in and spray and wipe everything with a degreaser when I'm done.
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8 NEW: 08 Evoluton 10 |
#22 |
^^^^ yeah those things are the best. Once again this is about having the right tools! You can have oil filter grips, the slip rings, or the ratchet deals which I dont know the right name of but are definitely my favorite for most situations. The correct tools and some brakeclean and the whole spiel is a breeze. Reguarding never seeing filters mounted in such a manner, you havent done to many oil changes then. Some manufactuers put the filter in the most ridiculous places ever. Ford Taurus for example. Oil filter is placed on front of the block above the catalytic converter and directly next to the starter. Anyone know how hot a catalytic converter operates at?
#25 | |
Just spray the block down with some brake clean, and lube the seal good before instalation. Don't overtighten the filter, contact plus a turn is just fine. And rule number one for ANY engine swap: If you dont remove the filter before you install the engine, it is going to be stuck VERY well and be VERY hard to reach. So remove it while you can reach it easy!! |
#26 |
Hopefully, you replaced the mad tite JDM oil filter before you installed the engine. If not, it is a PITA to get a tool in there to loosen it.
Otherwise, it should be easy to loosen by hand. If it's tough, you need to work on your kung-fu grip. Once mastered, you will be able to use your palm to remove the most stubborn oil filter. FRAM is a good beginner oil filter to practice with; it has a bedliner/grip-tape-like substance that will allow you to get a firm hold on it. Spillage, alas, is a fact of life. Deal with it. GL, Todd 93 Coupe (needs oil change) 91 SE-R (needs oil change) |
