![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
NEW PRODUCT - Innovate Motorsports SCG-1 Integrated Boost Controller and Wideband Kit
![]() Introducing the latest product to come out of Innovate Motorsports, the SCG-1. This all in one controller not only provides you with leading edge wideband monitoring that you are used to from other kits but ALSO brings to the table an all new boost control solenoid only offered by Innovate! This compact 52mm gauge will reduce a cluster full of gauges down to 1 simple unit. You can display boost, Air/Fuel, Wastegate Duty Cycle and it also has a built in shift light should you so decide to use it! Be one of the first to get your hands on this leading edge product from Innovate Motorsports!! Link to purchase or feel free to call in!! http://www.mvpmotorsports.com/templa...bFolderID=1149 Regards, Robert
940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
PM sent!
Regards, Robert
I'd be in for a group buy should one exist. This is an appealing product.
89 240SX w S14 SR20; 95 JDM 180SX S13 SR20; 09 Acura TL SH; 18 Jaguar XE S |
#9 | ||
GM2 (SW/AW)
Wow, I just literally got done ordering 4 innovate gauges from MVP. Including boost/shift light & wideband. If I hadn't ordered them I would have paid like $30 more and got this gauge... Good to see better shit coming out after I just dumped $650 on innovate gauges.
Few questions from people I will post up from Innovate:
I will have the manual shortly. Check out this short SCG-1 setup and tuning guide we put together. http://www.innovatemotorsports.com/r...tup_Tuning.php The gauge controller does not have targeting. It’s open loop. You will need to set the percentages. We have a multi-solenoid controller due out in the fall that will have all the targeting you mentioned. Regards, Robert
It will basically be similar to like a Profec B Spec II. You set a percentage and that's where it will "try" to stay around. You will likely experience slight fluctuation like the profecs had. With the solenoid due to release later this year you set it and that's where it stays.
Regards, Robert
