![]() Join Date: Mar 2010
S15 T28 BB & OEM type x wing
Hello, I have two items I no longer need.
First, OEM 180sx kouki wing has the white plastic tab under the wing removed for easier install. all studs and nuts are in good shape, no cross threading. whoever installed it used a ton of double sided tape as a gasket. sold Second, S15 t28 Dual ball bearing version (14411-91f00) HKS actuator comes with DIF clocking adapters and s13 inlet/outlet for intercooler. comes with braided coolant lines (not pictured) comes with proper oil drain fitting for s13 sr20det and OE hose. works great, no smoking, no leaking, no play. only removed to upgrade. 600 obo ![]() ![]() ![]() ![]() Last edited by hartig; 01-03-2020 at 05:55 AM.. |
| 180sx, s15, turbo, type x, wing |
