| Businesses Review your dealings with commercial entities here. Remember: Fair and objective. Flaming, accusations, and complaints are not allowed. Zilvia is not a grievance forum. |
drautomotive.com told me the wrong info and made it RIGHT
I needed extended studs and i asked him if the part number was correct and he said yes. I ordered the studs and finally got to putting them on and the hole on the hub is way to big.
Here is proof of me asking him Here is the stud and hub. the hole is way bigger than the factory s13 240sx hub |
![]() Join Date: Jun 2004
Trader Rating: (73)
Why would you use those?
They're not for Nissans AT ALL (Chevrolet). They're not the right thread pitch either 12x1.5 Nissan is 12x1.25. Like, why did you even have them in your possession? http://www.summitracing.com/parts/ARP-100-7708 Drautomotive has NEVER done me wrong. I've used his conversion hubs for over 4 years any time I had a problem, he took care of me. I'm only leaving this thread up so I can reply and show how incorrect you are.
![]() Join Date: May 2012
Stud Specifications:
S13/14 Rear, S13 Front: ARP 100-7708 Thread Size12mm x 1.50 RH Knurl Diameter (in.)0.509 in. Underhead Length (in)2.500 in. Knurl Length (in)0.315 in. Quick-Start NoseNo S14 Front : ARP 100-7717 Thread Size12mm x 1.50 RH Knurl Diameter (in.)0.565 in. Underhead Length (in)3.000 in. Knurl Length (in)0.270 in. Quick-Start NoseYes Just some quick info off another site. Yes the thread pitch is different but new lug nuts solve that. |
Trader Rating: (73)
My teammate has extended studs (probably Nismo) that use 12x1.25.
I know that 1.5 lugs are way more common (what with honda's using that and stuff)
Hello,
I apologize for the misunderstanding and misinformation, truly. please reply to our private message so that we can have it figured out for you. Thank you so much and I apologize for any inconvenience.
240SX 5 Lug Wheel Hub/Bearings Conversions |
Sorry about that. Please check again. Thank you.
