![]() Join Date: Jul 2003
Trader Rating: (357)
These are used, the dust boots should be replaced.
SINCE TAKING THE PICTURES I HAVE REPLACED THE MISMATCHED HAT WITH ANOTHER MEGAN ONE ![]() ![]() ![]() ![]() ![]() ![]() From the megan site... Megan Racing Street Series Coilovers Spring Rates 8kg/mm (447lbs.in.) F 6kg/mm (335lbs.in.) R MEG-MR-CDK-NS14 32-way adjustable damping. • Single cylinder design (mono-tube). • Aluminum collars, brackets, and upper mounts. • SAE-9254 cold wound steel, linear rate springs. • Separate lower bracket allows ride height to be adjusted without sacrificing stroke or preloading the suspension. • Front camber adjustable pillow ball top mounts and rear pillow ball top mounts included and feature spherical bearing to give the driver greater feedback. Last edited by Bernie (NoVA); 02-01-2014 at 09:56 AM.. |
For anyone interested in his buying coils, but are nervous about the mismatched top hat. I have a front s14 Megan upper camber plate I can sell you for $25 shipped.
RELAX BRO!!!! |
