![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
Alternative Killswitch (nonFuelpump KS)
Anyone know where i could install another killswitch that would leave the ignition system with no power or the fuel inectors with no power? its an S13 ecu
Ive been reading over the wiring diagrams and i couldnt find a ground wire that would work, it looks like the ignition system goes to a "power Transistor" that grounds out in 2 different places. so i dont know if thats evena good idea or spot to put killswitches. I want another killswitch thats not the fuel pump. I just cant find a good ground to put one that wouldnt cause a fire but will also stop the engine from firing Im looking at Nissan's pin #4 for the ecu, it should be a red/black wire that comes from the eccs relay, im wondering if that would be an ok spot to put a killswitch even though its a positive wire Last edited by kyral; 02-04-2016 at 09:43 PM.. |
![]() Join Date: Aug 2011
And here comes the interesting questions: "why","what car", "what engine" and "what EMS" .
But really, why ? Why don't you just put a switch on the wire that goes from the ECU to the fuel pump relay and call it a day ? |
MY bad on that its an s13 ecu car and engine really shouldnt matter since all the s13 ecu's use the same pins for wiring to the ecu
but its an Sr redtop in an S13 hatchback I dont want the engine to even be able to fire and i want more than one killswitch |
The power transistors that command the injectors are inside the ECU so you can't do anything there. And i would not mess with the ignition either. If you don't want it to fire and don't want to wire an FIA switch, manually disconnect the power amplifier or the coil harness. There is no other (simple) way. edit: there is a "hacked" way, that would be to install a switch on the CAS signal line. But you have to shield the whole circuit as otherwise it will act as an antenna and may send false triggers to your ECU. |
#6 | |
What about breaking a connection to the eccs relay? that should cut off power to the ecu right? |
#7 | ||
![]() Join Date: Feb 2012
Trader Rating: (37)
My reason for doing this, Croustibat, was because I wanted something that someone wouldn't really think to look or hear for.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
#8 | |
![]() Join Date: Jun 2010
so where you going to place the switch?
Trader Rating: (37)
Where ever one pleases to. I have mine under the dash on the passenger side in an undisclosed location. The toggle switch is nothing fancy. The wires are hidden within the harness so they're not standing out like a sore thumb. Also, the toggle switch is the exact same colour that it's fastened to...extra camouflage.
#10 | |
#11 | |
Trader Rating: (37)
Yes sir, I am fully aware of this.
Completely rebuilt block and head w/ 40k miles. Enthalpy tune and all the crap that goes w/ it. AEM gauges, Bee*R, Apexi AVCR, steering wheel and Q.R. R32 seats, control arms, coilovers, Sil front, rims, brakes... Don't get me wrong, it's still a 240, but there are quite a few items there that will grab the right person's attention.
![]() Join Date: Oct 2005
If you're really from France. You wouldn't understand why theft deterrents needs to be put in place even if it's "not worth a dime".
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
I already had a car stolen and burned, thank you. It still was a crappy car that some idiots stole just because they could. If it had a kill switch, they would have burned it right there, which would probably have burned the place i was living in. So yeah, kill switch on a rusted piece of crap is stupid, as much as stealing them is stupid.
But the stupidest of all would be to actually drive a showy rusted piece of crap in a neighborhood full of idiots. Better move out than add bling to that piece of crap... because cut off switch ? If someone wants the car and can't make it start he's just going to wait for the owner and beat the crap out of him, tow it or burn it down. That is reality. Now I fail to see the point in your xenophobic remark, so you might want to explain it... do you mean "our thieves" are smarter ? |
#16 | |
Do you know a good place to wire in a killswitch or not? |
#17 |
Yeah, like i haven't already. He is a piece of advice : don't act like a paranoid fool if you don't like being treated like one.
You don't know anything about the wiring of your own car but you want to put TWO kill switches on a piece of crap. You don't want your car stolen ? Then move out. Best anti theft device ever. |
#19 | |
Sounds like someone just had a meltdown. Please keep going...I personally think "your thieves" are more desperate than "our thieves" from what it sounds like LOL How's the French economy?
